MOW car
17 years 5 months ago #4895 by bambuko
MOW car was created by bambuko
Using piece of Perspex and couple of MTL trucks I have made MOW ;) car for use on newly laid track.
It is particularly useful when testing newly handlaid track.
(All thumbs below are clickable and open full size pics)
File Attachment:
File Attachment:
In use on handlaid track
File Attachment:
Here testing MTL track:
File Attachment:
17 years 5 months ago #4898 by TerryH
Replied by TerryH on topic Re:MOW car
What a great idea, thanks.
17 years 5 months ago #4899 by Socalz44
Replied by Socalz44 on topic Re:MOW car
Chris, Nice. Code 30? Very nice. Where can I get some Code 40?? Cheers, Jim CCRR:)
17 years 5 months ago #4900 by bambuko
Replied by bambuko on topic Re:MOW car
thanks TerryH :)
it's nothing new (few things are ... ;) ) - I have seen it used in larger scales
I get all my rail from The 2mm Scale Association , but you have to be a member. Have a look in 2mm Association shops
In USA you can get code 40 (but not code 30 which I am using) either at:
Nscalesupply
or at:
Fastrack
17 years 5 months ago - 17 years 5 months ago #4901 by Socalz44
Thanks Chris. I ordered 5 pieces. Cheers, Jim CCRR:)
17 years 4 months ago #4904 by TailUK
Replied by TailUK on topic Re:MOW car
Could be adapted into a track cleaning car?
17 years 4 months ago #4906 by bambuko
Yes, you could make cleaning car like this, but (in my opinion) in Z, cleaning cars are not likely to work very well (if at all).
If you make it heavy enough to be effective, you will have difficulty pulling it.
If you make it light, there will not be enough normal force applied to rub the rails.
Best track cleaning advice is KISS :P
Or have a look here
But, if after all this, you still want track cleaning car - it is simple to make one ;)
If I were making one I would follow Aztec idea.
17 years 4 months ago #4908 by Socalz44
Chris, I can't believe it Nscalesupply cancelled my order for 5 pieces. They say they have a $20 minimum order policy. I'm not sure I want to order 15 three foot long pieces to make the minimum. I know I won't live long enough to use them. What to do? Cheers, Jim CCRR:unsure:
17 years 4 months ago #4909 by David K. Smith
Replied by David K. Smith on topic Re:MOW car
Jim, you only want five 3-foot lengths of raw Code 40 rail? I can help you out. email me: dks2855 at gmail dot com. Note that the postage is probably going to be a bear.
17 years 4 months ago - 17 years 4 months ago #4912 by spyder62
Replied by spyder62 on topic Re:MOW car
Send them in a Flat rate mail tube should be around 6 bucks and they will not get bent.
rich
Time to create page: 0.248 seconds
