- Thank you received: 188
Wood Trestle Bridge
- southernnscale
14 years 3 weeks ago #14350
by southernnscale
Wood Trestle Bridge was created by southernnscale
- markm
- Thank you received: 69
14 years 3 weeks ago #14354
by markm
Replied by markm on topic Re: Wood Trestle Bridge
Hi,
Model Railroad Magazine has a book that covers dimensions for wood trestle bridges (as well as others). A while back they were offering it as an e-book. The deck area is generally a number of timbers between the bents that support the ties, which are typically laid at half the spacing.
There is also at least one laser kit available.
14 years 2 weeks ago #14391
Replied by Socalz44 on topic Re: Wood Trestle Bridge
You might try the 'bible' of bridge building: books.google.com/books?id=NZEOAAAAYAAJ Jim
- smholt
- Thank you received: 2
14 years 2 days ago - 14 years 2 days ago #14489
by smholt
Replied by smholt on topic Re: Wood Trestle Bridge
Black Bear Con Comp has some info that can be used, even if you want to build a trestle from scratch:
www.blackbearcc.com/tjk_6lho.htm
On this page 2 drawings can be downloaded, that give you typical dimensions:
www.blackbearcc.com/drawings/sixlegdwg_p1.pdf
www.blackbearcc.com/drawings/sixlegdwg_p2.pdf
I used info from here to create my own trestle from scratch on my new Zmod module:
www.platelayer.com/silver-creek-zmod-layout-2.aspx
The following user(s) said Thank You: southernnscale, stonysmith
Time to create page: 0.894 seconds
