- Thank you received: 1
Turntable problem.
- Dampflok
17 years 11 months ago #653
by Dampflok
Chris M.
• Z Home Page • Bahnhof Breitenfurt – Ost •
Turntable problem. was created by Dampflok
Hi All.
Six days away from an exhibition and I have turntable problems.
When I started using the turntable for the first time in ages today, I noted that it fed the tracks radiating from it. However it has stopped doing that and it is extremely annoying as I was hoping to be able to use it to shed locos etc. during the exhibition. I have checked continuity and, apart from one, there is no link between the rails on the turntable and the rails feeding off it.
Fortunately I can still bring locos in one one entry road and I can probably bypass an isolating track on another but repairing the problem would be the ideal option. Any ideas anyone?
All the best,
Chris.
All the best,
Chris.
Chris M.
- Dampflok
17 years 11 months ago #654
by Dampflok
Chris M.
Replied by Dampflok on topic Re:Turntable problem.
Further to my last, I have found that if I lift the turntable it will make contact so, at least I can get the locos off under power but it's not a nice solution.
Chris M.
- Rowan
17 years 11 months ago #655
by Rowan
Replied by Rowan on topic Re:Turntable problem.
Who is the manufacturer and what model/cat number is it mate ?
- Dampflok
17 years 11 months ago #658
by Dampflok
Chris M.
Hi Rowan. :o)
Whoops; I tend to think Z scale = Marklin. (Slaps wrist.)
It's a Marklin 8998.
All the best from 'sunny' Skye,
Chris.
Chris.
Chris M.
- Rowan
17 years 11 months ago #662
by Rowan
I went to the english data base; but alas nothing on turntables[that I could see}
- Dampflok
17 years 11 months ago #663
by Dampflok
Chris M.
Hi Rowan.
What database would that be, Rowan? Sounds as if it might be useful.
Best wishes,
Chris.
Best wishes,
Chris.
Chris M.
- Dampflok
17 years 11 months ago #668
by Dampflok
Chris M.
OK, problem solved. I realised that I could get at the contacts by removing one of the dummy segments on the outer ring. By gently raising each contact in turn all was well except for one contact that had suffered terminal damage before I got the turntable. I will just have to live with that.
Chris.
Chris.
Chris M.
- ZFRANK
- Thank you received: 3
17 years 11 months ago - 17 years 11 months ago #673
by ZFRANK
Replied by ZFRANK on topic Re:Turntable problem.
I have build my own turntable (on my German layout), quite some time ago.
Underneath the turntable I have installed a pcb disk, which is divided in two electrical halves. they do have the same polarity as the tracks towards the turntable (I do have some restrictions in entering the turntable). The two rails on the turntable are connected to old relay contacts, which turn along with the turntable. The relay contacts supply track power from the two disk halves to the rails on the turn table. Simple but effective.
Maybe it helps....
Regards,
Frank:)
Maybe it helps....
Regards,
Frank:)
- Rowan
17 years 11 months ago #676
by Rowan
Hi Chris,
Märklin
Technical Resource Center
www.marklin.com/tech/
This is from Märklin in New Berlin , have not been to Märklin Göppingen .
Märklin
- Dampflok
17 years 11 months ago #679
by Dampflok
Chris M.
Hi Rowan.
Thanks for that. Mind you, as far as I could see, they aren't particularly hot on Z are they.
All the best,
Chris.
PS I have everything wired up at last and all but one switches are working!
All the best,
Chris.
Chris M.
Time to create page: 0.253 seconds
