- Thank you received: 175
RailKing RK275
- stonysmith
15 years 2 months ago - 15 years 2 months ago #11589
by stonysmith
RailKing RK275 was created by stonysmith
Peter.. thanks so much for sharing the picture. I LIKE the paint job.
I don't have a good place to put "directions" for models such as this:
On the top of the model, between the tanks and the cab is a "comb" shaped peice. That is designed to be cut off. It is a clip that you can attach underneath to the axles on the underside to hold the wheels in either the up or down position. (They actually can be rotated down for street usage, or up for track usage)
- PeterR
15 years 2 months ago #11591
by PeterR
Replied by PeterR on topic Re: RailKing RK275
Hi Stony
thank you. Wow, I see it now. It is very tricky. But it doesn´t work without cutting the Axles.
Peter
Peter
- stonysmith
15 years 2 months ago - 15 years 2 months ago #11592
by stonysmith
Replied by stonysmith on topic Re: RailKing RK275
- PeterR
15 years 2 months ago #11605
by PeterR
Hi Stony
at my Railkings the axle brackets and the wheels are fixed minimal to the chassis. I think it is a Shapeways bug.
After the cut it is all ok. It turns and the wheels rotate.
Peter
Peter
Time to create page: 0.347 seconds
