GS1 Shell
15 years 6 months ago #10914 by stonysmith
GS1 Shell was created by stonysmith
Since I started this journey, I have been very interested in building some shells. To this point, the coarseness of the Detail materials, and the required thickness of walls have combined to be restricting factors.
With the dual announcements of the Thek chassis, and Shapeways Frosted Ultra Detail.. things have aligned such that the time is now here.
I wanted to start with a switcher similar to this but I couldn't find good dimensions.
Reading some, I found that often older engines were often chopped up to make yard switchers.
Quite literally, I did that myself for this model. I started with this drawing:
I then chopped it down to a single truck, shortened the nose, etc. Here's the resulting computer model:
Here's the first test print (thanks to Karin for the pics!):
A couple of notes: The model needs a bit of tweaking. I need to open up the area below the couplers, and I'd like to smooth the roof over the cab more than it currently is. I'll get those changes done very soon.
I guess picking a name of "GS1" was unfortunate, because I want to go back and attempt the proto GS1. If anyone can suggest a name.. I'll be happy to change it.
For any visitors not familiar with the websites:
Stone Bridge Models LGThek Chassis
GS1 Shell on Shapeways
15 years 6 months ago #10915 by theshylion
Replied by theshylion on topic Re: GS1 Shell
Looks like an HO Hustler of the 50's to me. Bought one back then at the local drugstore for all of $14.95 ( Included engine, two, cars, caboose, ovaltrack, and small transformer)Only thing different is this one looks like it has hand rails and the cab is liitle higher to look over the engine cowl.
Dwight
15 years 6 months ago #10916 by soccrdad30
Replied by soccrdad30 on topic Re: GS1 Shell
Stony, I second Dwight's suggestion. I like "Hustler" very much. And the shell turned out very well. It looks like there is some room over the motor, to help weight the shell down?
And to take a step back in time, yes I remember the drug stores... but, I also remember we had a 'Dime Store' too. It was always fun going in them.
15 years 6 months ago #10917 by Fred
Replied by Fred on topic Re: GS1 Shell
Stony-- as this is a generic shell ( and a work still in progress)- with no SPECIFIC model-- I would add other details... A whistle on top of the cab, a bell ( could be just a bump) on the front and top of the hood, some details on the lower side skirts over wheels, spliting the cab side windows, and maybe a slight visor over windows on front of cab.
Looks like there is a coupler up front but not on the back??
You may delete any and all suggestions. ;)
15 years 6 months ago #10918 by stonysmith
Replied by stonysmith on topic Re: GS1 Shell
Well.. as much as I like the name Hustler.. That name is taken, and I was considering doing one of those too:
Porter Huster (HO)
Anyone like the name Bravado?
One of the switchers I looked up had a plain flat side and they talked about the fact that they had welded a peice of ordinary sheet metal across the side .. to keep idle hands and feet away from the moving parts. The reason you see 'details' on the side of the GS1 is that you're actually looking at the side of the truck itself.
I made a hole on both ends for couplers.. It looks like I need to just extend the hole so that it drops all the way to the bottom. (?someone gave me bad dimensions?)
Fred.. the whistle is blowing.. you've got mail.
  • Alaska Railroader
  • Premium Member
  • Premium Member
15 years 6 months ago #10919 by Alaska Railroader
Replied by Alaska Railroader on topic Re: GS1 Shell
What do you think about the name the "Rebel" or the "Lil Rebel"?
15 years 6 months ago #10920 by rvn2001
Replied by rvn2001 on topic Re: GS1 Shell
Stony,
The Porter Hustler (HO) is what I have been thinking of putting on top of a Marklin 0-6-0 steamer. I'd have to remove the siderods but it might work.
15 years 5 months ago #10921 by stonysmith
A few updates.. smoother/shorter roof.. opened the coupler slots, added rungs below the steps.
15 years 5 months ago #10922 by Mr.JA
Replied by Mr.JA on topic Re: GS1 Shell
Looking better, Stony! :laugh:
I like some of Fred's suggetions. Any chance to add some details to the side-skirts? :dry:
15 years 5 months ago #10923 by stonysmith
A bit of detail:
15 years 5 months ago #10924 by Mr.JA
stonysmith wrote:
A bit of detail:
Okay... okay... BUT... are those Z-scale springs? :dry:
And... and... what about rivets? Can you make Z-scale rivets? :P
15 years 5 months ago #10925 by stonysmith
Another update.. closing in on final..
15 years 5 months ago #10926 by soccrdad30
Stony, the little detail is coming along rather well.
Ok, on a geeky note, you could use the name "The Hull". As in George Hull, the father of stereolithography (1986). Link: en.wikipedia.org/wiki/Stereolithography
15 years 5 months ago #10927 by theshylion
Hate to be a nit-picker but these did produce heat, no exhust or fan?
Other wise detail looks great. Suggest using a modified Micro Trains GP9 Horn modified instead of a molded one.
Dwight
15 years 5 months ago #10930 by tealplanes
Replied by tealplanes on topic Re: GS1 Shell
John, don't you mean the Hulk? After all, this is such a monster. :laugh:
15 years 5 months ago #10931 by tealplanes
Dwight
Dwight, you do have a good point, but you'll have to convince Stony to either add a stack or perhaps make the exhaust yourself.
I don't know, what do you think guys? Would something this small need an official exhaust stack? See how little I know about trains....... :blush:
15 years 5 months ago #10934 by Fred
stack would look nice-- as would a GPS antennae and whip with squirrel's tail.
signed,
:woohoo:
15 years 5 months ago #10936 by Kelley
Replied by Kelley on topic Re: GS1 Shell
You going to have a molded headlight? Perhaps make it hollow so an LED can be placed there. Or you could go for one of those big honkin searchlight headlights.
15 years 5 months ago #10937 by stonysmith
signed,
:woohoo:
Fred.. I will be happy to attach a cat's whisker as the antenna. YOU get to tell Peg why you're taking scissors to the cat :laugh:
Yes, I added a bit of indentation inside to facilitate positioning a LED better. I am leaving the headlight solid on the outside, but you can easily drill it out and get access to the cavity behind. I would however give some thought to using fiber optic in this case. Another choice.. This material is very translucent. A LED under the shell pretty much anywhere will shine deep into the darkness.
15 years 5 months ago #10938 by markm
Replied by markm on topic Re: GS1 Shell
This is starting to look like a Davenport engine I used to watch as a kid:
www.bcrhs.org/Boulderrail/history/gwr/sugar.html
Time to create page: 0.391 seconds
