Designs that won't work
15 years 3 months ago #11419 by Mr.JA
Replied by Mr.JA on topic Re: Designs that won't work
David K. Smith wrote:
It's called a joke. I suppose I should have put a smiley there, but I can't stand them. (Sorry!)
Meanwhile, the motor is running and the gear train seems to be working. If it weren't for a prior obligation for the afternoon, I might have had it running tonight.
Yes... I know you were joking. Hence, my use of the embarrased smiley and the use of "Gee". No need for an apology, because I took no offence. ;) It takes a lot to hurt my feeling. :)
Good news about getting 'it' running. I'm sure many folkz are looking forward to seeing your first video of 'it'.
15 years 3 months ago #11424 by tealplanes
Replied by tealplanes on topic Re: Designs that won't work
Well David,
You have dashed my dreams to such an extent that now I'm very depressed and I figure the counseling sessions to put Humpty Dumpty back together again will likely run me about the same amount as your loco so I guess I lose all around.
I think I'll go find the highest pitcher's mound, climb up on top of it and throw myself off head first. Life is so unfair :silly:
Actually I kind of knew in advance that this was sort of a one of a kind project to begin with so I think I'm going to manage to cope with Monday after all.
Still, the challenge of the project and seeing someone bring it to completion, whether it runs like a scared rabbit or a drunken sailor is reason enough to be excited......sugar or no sugar Alex :)
15 years 3 months ago #11433 by David K. Smith
Replied by David K. Smith on topic Re: Designs that won't work
15 years 3 months ago #11436 by N/A
Replied by N/A on topic Re: Designs that won't work
David,
Outstanding!!! 4 grams on top eh? I haven't recieved my GE 25T from Shapeways yet so I don't know, but do you have any idea how much the shell weighs?
15 years 3 months ago #11437 by David K. Smith
Just a guess, since it's RP resin, probably a very, very small fraction of a gram--may as well make it out of paper.
The only way this could come close to anything resembling a functional model is if the shell was lost-wax cast in brass.
15 years 3 months ago #11440 by TerryH
Replied by TerryH on topic Re: Designs that won't work
Hello, I am not certain but it appears to me that the rear wheels are not perpendicular to the sides and not parallel to the front wheels. This could be a result of the angle of photography. It could also be the cause of the jerking motion. You may want to check it with some calibers. I think it is great, good luck with it.
TerryH
15 years 3 months ago #11442 by David K. Smith
You are right, one of the axles is not perfectly perpendicular to the sideframes. This is a consequence of having made it entirely by hand. However, it's not the cause of the jerking motion. Stalling and jerking is a result of being so lightweight; jerking at the end of the forward/backward travel is due to the fact that I did not throttle it down before reversing direction. I have been thinking of making a second mechanism using more sophisticated tools, since I now have a prototype from which to work; it would be much more accurate.
15 years 3 months ago #11445 by Cleantex
Replied by Cleantex on topic Re: Designs that won't work
I think that the jerking with no weight charge is mostly a problem of the power pickup on the axles end. Nickel-silver would bring better result than brass at this point.
15 years 3 months ago #11446 by David K. Smith
The wheels and track were not as clean as they could have been; after I'd shot the video, I did a more thorough job of cleaning, and it ran somewhat better. Having said that, I agree with respect to using brass, and future designs will utilize NS for any parts responsible for current transfer.
15 years 3 months ago #11449 by TerryH
David, thanks for the feedback, this is a learning process for me. I always appreciate learning new things :) I am looking forward to your next mechanism.
TerryH
15 years 3 months ago #11451 by tealplanes
David,
Just wondering if the slightly angled wheel set would would tend to make the loco more prone to derailment in either forward or reverse direction?
I had noticed the slightly off wheel set also. That's the trouble with not having all the sophisticated tools that make building more accurate. Still though a great accomplishment.
15 years 3 months ago #11454 by David K. Smith
tealplanes wrote:
David,
I don't think it would have made much difference. But if I do complete a new one, it won't matter because I have the equipment needed to "make it right," and the guts of the first one will get recycled.
Time to create page: 0.262 seconds
