I just built a grassinator.
17 years 7 months ago #3280 by Socalz44
Replied by Socalz44 on topic Re:I just built a grassinator.
Tony, Sorry, I'm sort of dumb with electrics. Can you make me a diagram and post it. Like what to set my volt meter on, where the red and black probes go?? Thanks, Jim CCRR:unsure:
17 years 7 months ago #3282 by zmon
Replied by zmon on topic Re:I just built a grassinator.
Jim
Here's the link the the original file John C post on building the grassenator and if you scroll down a bit there is a great diagram..
racooke.com/images/HOW%20TO/Static/Making%20a%20Static%20Grass%20Applicator.pdf
Tony B...
Wasatch Z Club
17 years 7 months ago #3284 by growermn
Replied by growermn on topic Re:I just built a grassinator.
There is also a new update on using a different power source, might be worth looking at jeff
17 years 7 months ago #3285 by Socalz44
Jeff, I'm using that new one. I think I have a problem with the wallwort, the on/off switch or the panel mount jack. The wiring is done correctly so it has to be one of the components. Which one I haven't a clue. Cheers, Jim CCRR:(
17 years 7 months ago #3301 by SJ-BAZ-man
Replied by SJ-BAZ-man on topic Re:I just built a grassinator.
Jim, great work there ! Static grass is really neat.
John, Nice update on the kit. The mom-shorting barrel connectors are the only way to go. But a suggestion for all: either tie the cord around the body or mount a 'snap in' cable restraint to keep the power from coming out while you dragging the cord around. Not likely, but . . .
John, have you thought of an adapter using a few inches of 3/4 or 1/2 PVC to get a locally concentrated area, like the newer Noch's have ?
Chris Tatarian of the BAZ BoyZ made up some laser cut adapters for his, cuts down on the plastic grinding.
Now where is that ion generator I found several years ago ??? Should build one for a gift on my Oslo Zmod trip.
16 years 3 months ago #9397 by TheWag
Replied by TheWag on topic Re:I just built a grassinator.
Looks like someone else "Just built a grassinator." See Railroad Model Craftsman July Issue.
Time to create page: 0.231 seconds
