AZL 7006 Dallas TRE Bombardier cars ready for DCC?
18 years 2 weeks ago #416 by hmseyn
Hi, i did purchase the AZL 7006 Dallas TRE with Bombardier cars. It was mentioned ready for DCC. I do not see how to connect the Decoder,i would loke to install an Uhlenbrock or Digitrax DZ125. could you please email me the instructions.
Also i need to replace the loco headlight, could you please tell me where i can purchase the psare part.
Thank you for your help
Henri
18 years 2 weeks ago #417 by jlundy46
I just emailed you with some information.
18 years 2 weeks ago - 18 years 2 weeks ago #421 by shamoo737
Henri, here is the link to pictures on how to install it.
www.zcentralstation.com/index.php?option=com_wrapper&view=wrapper&Itemid=92
Go to page 12 of the album, and the pictures are on the middle of the page.Click on the descriptions to blow up the pictures.
18 years 2 weeks ago - 18 years 2 weeks ago #426 by shamoo737
This is what the installation looks like.
18 years 2 weeks ago #427 by hmseyn
Thank you for the detail installation instructions and pictures.
a picture give more than a thousand words...
Thank you again.
Henri:)
18 years 2 weeks ago #429 by jlundy46
Hi Henri,
I just emailed you pics but you may already have them from the archives. Hope they help.
18 years 2 weeks ago #430 by jlundy46
Hi John,
It doesn't look like you had to cut the tray to get the decoder to fit. I have a F59 PHI I want to install a decoder in and have both a Digirax DZ125 and a new CT Elektronic 75. The latter is smaller since it has no covering.
18 years 2 weeks ago #431 by shamoo737
Henri, I had to cut the tray with the DZ125. Its still too big, but with the CT decoder, you dont have to. I would go with the DZ125, because its cheap compare to the CT. Save the CT for the SD70s or GP7 where its small size is a must.
18 years 2 weeks ago - 18 years 2 weeks ago #432 by shamoo737
John, on the DZ125, it has the BEMF, turn it off. It will overheat the motor. BEMF doesnt work with coreless motors.
18 years 2 weeks ago #434 by jlundy46
Thanks for the tip John. Do you know if the Marklin 2-8-2 motors are coreless?
18 years 2 weeks ago #435 by shamoo737
John, they are not coreless. They are either 3 pole or 5 pole. Just dont get a Uhlebrock decoder on a Marklin. They will overheat the decoder and shut down.
18 years 2 weeks ago - 18 years 2 weeks ago #439 by jlundy46
Thanks John. I will be using a DZ125 in my Marklin. I sure appreciate the wisdom and experience of those who have gone before - what I don't know would fill volumes!
18 years 1 week ago #451 by SJ-BAZ-man
John and John, the DZ125 out of the red plastic ought to be damn close the the same 'height' as the CT.
Lundy-man, try and save that small sq inch CT for a cramped place.
Turning off the BEMF functions (CV 55, 57 and one other if I am not mistaken) still did not turn the functions off on my testing on a 5 pole PM motor. I could clearly see the BEMF effects on my oscilloscope. Digitrax, if I am not mistaken, does not turn the BEMF on by default. Make sure Momentum is off (All DCC Programming track routines, like NCE's Cabs do in Standard Programming) do this in a prompted text menu. Or, you can program CV3 & 4 to 0. This is an NMRA standard for all decoder manufactures. BEMF is not a standard so everyone uses their own CVs for that.
Haven't run a Digitrax on the AZLs but have run the Lenz Mini's (buy the Silver one as the more expensive Gold only adds support for the external PS1 or what ever the power supply model is). They DO have BEMF defaulted on and you cannot shut it off. Mine have run OK.
18 years 1 week ago #454 by jlundy46
Hi Jeff,
Yes, I will use the CT decoders for AZL GP7s and the SDs. So the BEMF should be turned off on the DZ125. That's good to know.
18 years 1 week ago #455 by shamoo737
Jeff, it used to be that you void the Digitrax warranty if you took of the wrapping. I dont know if this is still true. Also, are you saying that you cant turn off the BEMF on the 125?
On the wiring, yes, I did make a mistake, but I fix it by programming. I didnt want to re-solder the wires.
18 years 1 week ago #471 by SJ-BAZ-man
Maybe you void the warranty but for $20 a 125, I'd rather have it fit and have better air circulation than worry about the hassle of a warranty return. Don't you have to send them $10 anyway ? (plus mailing, etc.)
18 years 1 week ago #472 by shamoo737
Nope, you just have to send in the decoder. There is no charge for exchanging the decoder. The only time they charge me is on a 123, and I open the wrapping.
18 years 20 hours ago #680 by hmseyn
I did the install as per your instructions and it work well, it tooks sometimes but work.
Thank you for your help.
Henri
Time to create page: 0.524 seconds
