NCE PowerCab, SmartBoos3 & DCC Specialities PSX-AR
17 years 6 months ago #4062 by JackC
Have any of you had any experience in making the NCE SmartBooster3 operate with the NCE Powercab AND the DCC Specialities PSX-AR? Right now when the engine hits the isolation cut that should switch the polarity in the reversing loop, the SmartBooster trips first! I have tried low value resistors, the automotive light bulb trick and moving the SmartBooster to be as far from the light bulb as possible. It has been suggested that I place a high value ceramic capacior across the power feed to the track as a "snubber," but that has mixed acceptance. I believe that the auto reverser is set for the lowest trip value. Frankly, I am running out of ideas, but I do want to operate my layout with multiple throttles/controllers.
Do any of you have any other ideas for me?
Regards,
Jack C
17 years 6 months ago #4072 by zmon
Hi Jack!! Good to see you over here on ZCS, this is my favorite Z site, and the first one i check in on every day... Hey fellow ZCS freinds, this here is Jack C. one of the Wasatch Z Clubs best members. Jack's building four modules, and there coming along great!!
Jack, like i said in my last email, i out of ideas on the reverser problem. Hopefully you can get some advice here from some of the DCC folks like Jeff.
Hey Jeff!!!! Do you know of this problem and can you help Jack out???
Tony B...
Wasatch Z ClubB)
Time to create page: 0.306 seconds
