Shapeways Project in progress Mi-Jack
12 years 7 months ago - 12 years 7 months ago #17177 by southernnscale
Shapeways Project in progress Mi-Jack was created by southernnscale
This is my newest project working on. I hope it print out good. It has two pieces but pricey! the main part cost the most and I have tried to keep the material down but still working on it but as is I have it passing in FUD material. :woohoo: Having fun trying! I will see if it prints soon!
12 years 7 months ago - 12 years 7 months ago #17179 by HoboTim
Replied by HoboTim on topic Re: Shapeways Project in progress Mi-Jack
Resin
Etched Brass
Air brushing
ALPS decals
LEDs
To view lots more custom Z and Mi-Jack photos go to this link!
www.trainboard.com/railimages/showgallery.php/cat/500/ppuser/3893
Hobo Tim
12 years 7 months ago #17180 by HoboTim
www.trainboard.com/grapevine/showthread.php?86835-Z-scale-Mi-Jack-Translift-Container-Cranes
This is the link to the second run of Mi-Jacks that were made a few years ago.
It appears interest has yet arisen again!!!!!!!!
Hobo Tim
12 years 6 months ago #17189 by southernnscale
Replied by southernnscale on topic Re: Shapeways Project in progress Mi-Jack
working on yard mule just 3D drawing in progress!
12 years 6 months ago #17196 by southernnscale
another order arrived and here are what I had done! I Have a Deep well car 74' long have two CSX 53' containers. I have a Coil car it's 55' with removable covers and have six coils 3 under each cover. and a 40' Cattle car
12 years 6 months ago #17217 by Jimvane
Replied by Jimvane on topic Re: Shapeways Project in progress Mi-Jack
Are you still making the MiJack intermodal container handler? Are they for sale? What do they cost ?
Thanks...
Jim
12 years 6 months ago #17219 by Pig Gap
Replied by Pig Gap on topic Re: Shapeways Project in progress Mi-Jack
That cattle car looks nice. I wouldn't mind having one. How do you paint these Shapeways models. I read the tread about removing the waxy surface, but after that, do you prime them before painting?
12 years 6 months ago #17220 by stonysmith
Replied by stonysmith on topic Re: Shapeways Project in progress Mi-Jack
I use a product called Bestine - 10 minute soak and all the 'wax' is gone, and the external surface turns an opaque white as though you had primed it. In that state, it holds the paint very nicely.
Of course... "StonyCan'tPaint"....
12 years 6 months ago #17224 by Pig Gap
I know all about Bestine, as my wife use to "wax down" ads and articles in newspapers. I just didn't know if they required priming before painting. I know brass takes paint better if primed than not primed (after a white vinegar bath.)
  • Alaska Railroader
  • Premium Member
  • Premium Member
12 years 6 months ago #17228 by Alaska Railroader
Replied by Alaska Railroader on topic Re: Shapeways Project in progress Mi-Jack
I have bought hundreds of items from Shapeways and highly recommend giving them a couple of light coats of white primer all around. It gives it some degree of additional strength, helps to fill in some of the look of porosity, and helps any other colors you add look better. I always always primer them white.
12 years 6 months ago #17235 by southernnscale
My new mixture of Showcaseminiatures and Shapeways I made a bed for one of the stake truck I bought for my propane tank dealer. It has a small crane to off load propane tanks for delivery to your house.
12 years 6 months ago #17246 by southernnscale
This is the Motor car with bottom insert for seating.
12 years 6 months ago #17249 by southernnscale
Building Sign boards. for roof tops this is the one I did for Ferguson's Wearhouse I did in wood!
Built so it can be wired with low heat lamp since made of FUD. has ladder and sign power switch in middle bottom switch doesn't work. This is small sign little over 1" high 1 3/4" long
12 years 5 months ago #17294 by southernnscale
Another piece of equipment, diesel Excavator P&H 1055B
Time to create page: 0.347 seconds
