AZL Loco
17 years 9 months ago #2649 by eit27
AZL Loco was created by eit27
Does anyone have experience in changing out the factory lamp to LED? What ohm resistor is needed if any? Thanks.
17 years 9 months ago #2652 by shamoo737
Replied by shamoo737 on topic Re:AZL Loco
What engine are you changing. All AZLs that have lighting have leds.
17 years 9 months ago #2657 by eit27
Replied by eit27 on topic Re:AZL Loco
Thanks for the reply. I have a SD70M, didn't realize they were LED. Is it the same for the MTL GP35?
17 years 9 months ago #2660 by shamoo737
yes, the GP35 has leds also. You can make them brighter by replacing the plastic light inserts with fiber optics. Thats what I did on most of my GP35s and SD70s.
17 years 9 months ago #2661 by eit27
Do you have a good source in which to get the fiber optic material? What diameter of the fiber optic that was used? Thanks.
17 years 9 months ago #2662 by shamoo737
Well, I dont know the actual diameter of the fiber optic. I got my fiber optic from a night light, and I bought it from a Publix Supermarket. I see Fiber optics being sold on Ebay all the time, but for me, it was cheaper and more convenient to buy it from Publix. One night light is enought to convert all my engines and still have enought to do more.
17 years 9 months ago #2663 by eit27
Thanks for the help. Some of the simplier things are often over looked.
17 years 9 months ago #2665 by bambuko
Replied by bambuko on topic Re:AZL Loco
have a look here:
fiberoptic shop
17 years 9 months ago #2666 by shamoo737
Elf, this is the fiber optics I used. After cutting it, I use a solder iron to melt the tip, so that it has a smooth lens.
17 years 9 months ago - 17 years 9 months ago #2667 by shamoo737
17 years 9 months ago #2669 by eit27
Many Thanks. This is a major improvement.
17 years 8 months ago #2846 by dominique
Replied by dominique on topic Re:AZL Loco
On another one can notice MTL's GP9s have a far better shining headlight than GP35s and AZLs. Should not it be possible to order some fiber optic directly at MTL's?
17 years 8 months ago #2847 by davidf
Replied by davidf on topic Re:AZL Loco
the GP9s have plastic headlight inserts designed into them, the are not fiber optic. i don't think MTL uses or sells fiber optics. you might see if they offer the len inserts for sale separately, but it would be up to you to make it work for your application. the biggest problem will be that the lens insert is made to fit the spacing between lights on the GP9 -- and i think that is different than what it is on the GP35. i don't know if they will fit in AZL locos. fyi.
dave f.
17 years 8 months ago #2848 by shamoo737
Dom, the AZL Leds are not as bright. I been meanig to switch out one the leds to see if it makes a difference. I think it also helps if you installed fiber optics. If you really want it bright, instal a smd right behind the fiber optic.
17 years 8 months ago - 17 years 8 months ago #2849 by SJ-BAZ-man
Replied by SJ-BAZ-man on topic Re:AZL Loco
All American (AZL and MTL) locos use LEDs. Only Märklin uses ordinary light bulbs (torches for the UK folk). AZL uses a much more yellow (Amber) one. You could replace it with a "white" LED but most are sooooooo brite now, you will have to lower the current thru by increasing the resistor value. There already is one on the Printed Circuit Board (PCB ) but you can add another 470 to 10000 ohms in series by cutting either LED lead of the new LED. You could make the AZL LED brigher by adding another Surface Mount (SMD) resistor across (in parallel) with the one on the PCB.
Note: White LED's are NOT white, they are blue with a yellow phospor that ""looks"" white. BUT, if you reduce the current thru the LED from it's stated range, they will not be as "white" but more bluish. Most white LEDs are now in the 100,000 mcd (milli candella), a measure of the light output. We only need <<<<100 mcd to light one of the headlights !!
Fiber optics really help. You can leave them long (coil into one loop) and mount them into the LED. Attaching to a normal T1 (bullet shaped one) is easy: drill a small hole in the end to accept the fiber optic and glue in place. The LED is expoxy so plastic cement (model making) won't work. CA (e.g. Super or Crazy Glue) will 'craze' the fiber, making cracks and fogging it but it still works, just a little light loss and more brittle. Attaching to SMD LEDs like the later Digitrax decoders for the MTLs is not as easy. You will have to glue it the PCB in front of the LED, trying to get it lined up with the LED and it still may not be bright enough.
MTL nor AZL do not sell the plastic light pipes and defintely do not seel fiber optics.
17 years 8 months ago #2850 by Kelley
Replied by Kelley on topic Re:AZL Loco
For Mareklin engines I recommend the little circuit blocks with built in LEDS from High Tech Modelbahnen. They are bright and constant, and turn on with very little power. I have them on my Mikado and they fit where the light bulb goes in. They come in white or yellow tones. If they are too bright, then go over the leds with a bit of permanent marker and it will tone them down.
17 years 8 months ago - 17 years 8 months ago #2852 by TerryH
Replied by TerryH on topic Re:AZL Loco
Kelly, thanks, I will pick up one for my Mikado.
17 years 8 months ago - 17 years 8 months ago #2853 by jlundy46
Replied by jlundy46 on topic Re:AZL Loco
Bambuko, thanks for the link. I just ordered one of their kits with various sizes of materials so I can find what works best for me. I have some AZL Sd40-2 that need lights and I'd like to improve the looks of the lights on other locos.
bambuko wrote:
have a look here:
fiberoptic shop
17 years 8 months ago #2859 by ztrack
Replied by ztrack on topic Re:AZL Loco
We do import the HTM LEDs. We also have quite a few in stock. You can find a listing at:
www.ztrackcenter.com/htm/marklin/
The HTM plugs are by far one of the most popular items we offer. They are a great improvement over Marklin's grain of wheat bulbs.
17 years 8 months ago #2966 by dominique
Myself I used a LED from Richmondcontrols ( www.richmondcontrols.com ) for one of my AZL Dash9, and it's very easy and quick to install, 2 minutes maximum once you removed the shell). The result is fine.
Go to this page for more information: www.richmondcontrols.com/EZ00.pdf
Time to create page: 1.095 seconds
