Monday, November 09, 2026
Beverly's and Chris's Slab Door Layout
16 years 5 months ago #9158 by Beverly56
Replied by Beverly56 on topic Re:Beverly's and Chris's European Layout
John,
Last spring I bought a big container of Woodland Scenics extra fine ballast. I recently did a test of this ballast. The biggest problem using it was static electricity makes brushing it evenly somewhat difficult. The finer the particle size, the bigger the static problem becomes, at least that's what I surmise. What's your take on the static problem with the product you suggest?
On a completely different note, it's finally spring in the Great White North :woohoo: Well, mostly it's been spring. On May 6th, we had a snowstorm with about 4" of snow. Here's what it looked like from our kitchen door...
May 30 also brought overnight snow. It mostly melted upon contact with the ground and there was no point in taking photos.
The skies here have been totally wonderful lately and I took time to create a few more timelapse cloud videos. For those who are interested....
Timelapse Clouds, May 18, 2010
Timelapse Clouds, June 4, 2010
Timelapse Clouds, June 5, 2010
Timelapse Clouds, June 6, 2010, at about 5:00 p.m.
Timelapse Clouds, June 6, 2010, at about 8:30 p.m
16 years 4 months ago #9171 by shamoo737
Replied by shamoo737 on topic Re:Beverly's and Chris's European Layout
Bev, my ballast works better. Its smaller the Woodland Scening and its less uniform in size. I also less likely to float when you are applying the scenic glue. My biggest problem is that my layout is mostly covered with Woodland Scenic ballast. I know its going to be a pain to take it out.
16 years 4 months ago #9175 by Beverly56
John,
I haven't had any problem with floating ballast when adding the glue. I follow the WS instructions by adding drops of alcohol to the ballast prior to gluing and the glue soaks in immediately and without any problems.
I'mm still wondering about how easy it is to actually ballast the track with your particular ballast in terms of static.
FWIW, here's our micro-layout that has WS extra fine (or fine, or whatever it's called)...
Forget that I didn't weather the track. It was a rookie mistake. But I'd like opinions on whether or not the ballast looks "okay". It doesn't have to look "spectaular". "Okay" is fine with me :)
16 years 4 months ago #9179 by shamoo737
Bev, if you like the look its all the matter. You do such a great scenery its going to make everything look good. Also, Arizona Rocks are not the esiest to find.
16 years 4 months ago #9180 by eit27
Replied by eit27 on topic Re:Beverly's and Chris's European Layout
Bev, I have used both. I too am in the same situation as John, I have so much of the WS ballast already down.
The WS ballast is made out of crushed walnut shells I believe, which makes it subject to Static electricity. The Arizona ballast is made from actual crushed rock. I have not experienced static problem with the Arizona.
You may try grounding yourself before you begin to ballast. It possibly could be the transfer of static from yourself to the layout. Just a thought.
16 years 4 months ago #9181 by Beverly56
John,
I'm not thrilled with the look of the WS ballast, but I can live with it. Let's put it that way. I can change the stark grey colour by giving it a few washes of paint.
Ed,
I don't think WS ballast could be crushed coconut shell. Coconut shells are fibrous and are quite a bit lighter than how the WS ballast acts and feels. At least that's how it seems to me. I've worked with sand in a different application in much the same way as the ballast and have had similar static problems.
Question du Jour: How do I ground myself??
16 years 4 months ago #9182 by Socalz44
Replied by Socalz44 on topic Re:Beverly's and Chris's European Layout
Interesting about the ballast. I use WS ballast for all my track laying and have never had these static electricity issues. I live in a benign climate and lightning and thunderstorms are very few and far between. Maybe this is why I don't have static issues. That said, I don't believe WS ballast is any more than crushed rock or plaster of some sort. Hard to comprehend the amount of coconuts needed for WS ballast inventories. Cheers, Jim CCRR:)
16 years 4 months ago #9183 by shamoo737
Bev, Ed said walnut and not coconut.:laugh: I dont know what is it, but it doesnt feel like a real rock. On the look, its too uniform and overscale. Robert calls it rats turd.
I try to use washes, but it cant mask its uniform size.
ED, why dont you post the picture of you Arizona Rock ballast. Maybe that will help Bev with her decision. Also let her know what is the minimum order amount.
16 years 4 months ago #9184 by Beverly56
Duh! Yes, Ed did say walnut :dry: I can see how they could get the itty bitty sizes of WS ballast from walnut, but not the larger sizes. Walnut shells aren't thick enough to do the larger ballast sizes.
When in doubt, test the material :) Between my thumb and forefinger, I easily managed to crush the ballast into finer particles. Dust similar to clay dust was left on my fingers. Too much pressure while crushing the ballast results in dust only, so be careful when crushing it. From this little test, I'm going to surmise that WS Ballast is made from a crushed dried clay type of material.
Left, Woodland Scenics Fine Ballast. Right, crushed WS Fine Ballast. Middle, dust residue on my finger.
Hope that helps shed some light on the subject :)
16 years 4 months ago #9185 by Socalz44
He said, she said, I said coconut. My bad. But I did say plaster type material. Jim CCRR:blink:
16 years 4 months ago #9186 by Beverly56
Whatever it's made of, it can be altered to have non-uniform sizes :)
Here's a quick video of the method I used to crush it...
Crushing Woodland Scenics Fine Ballast.
16 years 4 months ago #9188 by shamoo737
Wow, what big fingers your have, Bev. :laugh: With Arizona Rocks, you dont have to anything. Its already the right size, but its good to know you can make your own with WS ballast.
16 years 4 months ago #9190 by Beverly56
Dude! I have the hands of a Giant :D
Crushing the WS ballast with my fingers only works until my fingers get sore - which is pretty quick. Now I'm using two flat stones to crush it. Too bad it takes so long, but I'm pretty happy with the results. Good thing we had this discussion. My problem solving skills are always up to finding solutions to things :)
16 years 4 months ago #9203 by eit27
Replied by eit27 on topic Re:Beverly's and Chris's Slab Door Layout
Hi Beverly,
Here is the ballast that John was referring to.
16 years 1 week ago #9885 by shamoo737
Replied by shamoo737 on topic Re:Beverly's and Chris's Slab Door Layout
Bev, do you have any updates, or you hurt your fingers crushing the gravel. :D
16 years 1 week ago #9887 by Beverly56
Hi John,
First of all, let me congratulate John (the other John) on his great work with ZCS! The site looks fantastic, dude! Many thanks to everyone who has contributed their time and effort behind the scenes with John to keep ZCS a wonderful place to visit and contribute to Z B)
As for me, I crushed all the gravel on hand (no pun intended, but yes fingers were very sore afterward :blink:) and moved forward with my other hobby on a rather grand scale. Our Z scale work will be on hold again, though I know not when we'll get back to it.
For those who are interested, my other hobby is creating videos of my collection of the UK, Japanese and N. American Sylvanian Families/Calico Critters range of toys. While I do make videos for my personal YouTube Channel , my primary task these days is producing viedos for an online store located in Australia that sells these toys. I receive free toys (a collector's dream!) in exchange for making short videos for the store.
In late August, I received 75 boxes of toys, photographed in our basement room where I produce the videos in a very large display cabinet...
In September, we built a bridge to go with the Old Oak Hollow Tree House, photographed here with the Seadog Family...
In mid-September, I stumbled onto a huge 50% off sale at Michaels where I bought loads of materials to create trees for the videos. Here's a photo of me sculpting tree trunks out of the CelluClay/drywall mud mix I use for Z...
And here's what the trunks looked like after they dried and were colour washed a couple of times...
The following are scenes from some of the videos produced for my Australian friend...
These photos are of various buildings set up and ready to create videos...
My Australian friend's YouTube Channel where the videos I make for him are uploaded.
There is a chance that Chris and I will go to Australia to create a similar permanent Sylvanian Families display in a storefront that is in the very early stages of planning. Money and time on both sides of the Pacific are considerations that will determine if we will actually go. It would be a once in a lifetime opportunity to do such a grand project and to live in Australia for a few months during construction. Even though the chances of going are slim, due to global economic problems, I do sometimes let myself drift away into the dream of walking the beautiful Jervis Bay beaches :)
Once I get back to Z, I'll continue posting updates of our progress. Thank you, John, for asking about it :)
16 years 1 week ago #9888 by shamoo737
Bev, I wish you luck on your dream vacation. Your other hobby looks great,and I can appreciate the artistic work that went into it.
16 years 1 week ago #9909 by soccrdad30
Replied by soccrdad30 on topic Re:Beverly's and Chris's European Layout
Bev, thank you very much for the compliment. I really hope everything works out for you and Chris to create a permanent setting. I think that would be a fantastic trip. Isn't it interesting how one's hobby can branch out into other areas of knowledge and expertise? John
Time to create page: 0.319 seconds
