Anyrail module templates
12 years 6 months ago #17237 by ModelWarships
Anyrail module templates was created by ModelWarships
Does anyone have any Anyrail templates for any of the Z track modules available for download?
Timothy Dike
12 years 6 months ago #17241 by chaz
Replied by chaz on topic Re: Anyrail module templates
I not familiar with Z track. I'd like to read the standard.
12 years 6 months ago #17242 by stonysmith
Replied by stonysmith on topic Re: Anyrail module templates
12 years 6 months ago #17243 by rvn2001
Replied by rvn2001 on topic Re: Anyrail module templates
Are you asking about Z-Bend Track modules or something that ZTrack Magazine has done? Stony's link above will get you to the standards for Z-Bend Track. I think I may have one or two Anyrail trackplans for Z-Bend track modules.....just 2' x 4' straight-through modules though.
12 years 6 months ago #17244 by ModelWarships
Replied by ModelWarships on topic Re: Anyrail module templates
I would like to do a standard Z-scale module to take to shows. Is Z-bend the accepted standard?
If you have a plan for a 2x4, that would be great. I can modify to suit my needs. I'm hoping I can find enough locals in the Kansas City, Mo. area for a club that would help spur interest in Z.
Timothy Dike
12 years 6 months ago #17247 by chaz
My 24x48x2.5 modules are not per any standard. They are shorter and lighter. I plan to exhibit them as table top modules at shows (like Thomas) and operate them as table layouts at home.
I should be cutting parts in less than a month. I work at a cabinet shop and we are swamped at the moment. Darn economy. Even though I am using Rokuhan track with the built in roadbed, I'm also going to cut 1/2" thick foam insulation so I can elevate the track. It makes it easier to make cuts and fills.
[url=http://www.zcentralstation.com/index.php?view=category&catid=340&option=com_joomgallery&Itemid=178[/url]
If you have specific needs, I'd like to know about them.
Chaz
12 years 6 months ago - 12 years 6 months ago #17248 by rvn2001
Z-Bend Track is the most widely used module standard in the United States. There is a list of groups in Ztrack Magazine.
Here are 2 track plans using Rokuhan track but you can use any track you like. They are basically 2 sets of main lines located 9" and 10" from the center of the module set back 2 1/8 " from the ends of the module.
One is fairly simple and the other will allow you to run a train on your module whether you're connected to other modules or not. I hope this will encourage you to build a module.....or two.....or three.....
The following user(s) said Thank You: ModelWarships
12 years 6 months ago #17253 by ModelWarships
Actually it was this super cool Powder River Coal Flood loader kit by Stonebridge Models that prompted me to build a module. I have a small coffee table layout that was just too small to use it in. So a module would allow me to have my coal mine, and hopefully meet up with other local Z-scalers while promoting Z scale at the same time. I used to belong to a local HO club and enjoyed setting up at the shows and running trains.
Timothy Dike
12 years 6 months ago #17254 by Guba
Replied by Guba on topic Re: Anyrail module templates
I have to say that I found this VERY enlightening! :) I hope to see this kind of set up in Cleveland this summer.
12 years 6 months ago - 12 years 6 months ago #17255 by rvn2001
You're in luck, Guba! The top module will be part of the MidweZt HaulerZ display in Cleveland this summer. Please be sure to introduce yourself when you find us. We'll be way back at the end of the hall. Bring some trains to run if you want to.
12 years 6 months ago #17256 by Guba
I'll be sure to say hello! ;)
12 years 5 months ago #17270 by SJ-BAZ-man
Replied by SJ-BAZ-man on topic Re: Anyrail module templates
Thomas, can you save the Anyrail file of the figure 8 module so we can download it. Or: print, handwrite, scan and repost so that we can recreate.
That's a good idea module. We can use as a stand-alone or, a module (layout) joiner.
12 years 5 months ago - 12 years 5 months ago #17271 by rvn2001
Jeff,
File Attachment:
File Name: DollhouseM...Rok2.zip
File Size:5 KB
Thom
9 years 1 month ago #18274 by railtwister
Replied by railtwister on topic Re: Anyrail module templates - Chaz' Modules
chaz wrote: My 24x48x2.5 modules are not per any standard. They are shorter and lighter. I plan to exhibit them as table top modules at shows (like Thomas) and operate them as table layouts at home.
Chaz
Chaz,
Any updates on your progress with your Z modules? From the photos, it looks like you pre-fabed a bunch of sections (probably more than one person should have to be responsible for).
Bill in FtL
Time to create page: 0.715 seconds
