Transfering cadrail drawing to benchwork
- Stiv44
13 years 7 months ago #15181
by Stiv44
Transfering cadrail drawing to benchwork was created by Stiv44
Ive read some articles and would like to know how some people transfer there layout ideas from a computer program / drawing onto the bench work. I have seen how some people use a simple striaght edge with a 90deg portion on it to draw certain radiuses and such. Most say start with the yards and go out from there. Also how do some of u draw in your easment since i have not done so on my curves.
Thanks.
Thanks.
- jrb
- Thank you received: 6
13 years 7 months ago #15183
by jrb
Replied by jrb on topic Re: Transfering cadrail drawing to benchwork
- Stiv44
13 years 7 months ago - 13 years 7 months ago #15218
by Stiv44
Replied by Stiv44 on topic Re: Transfering cadrail drawing to benchwork
looks like you drew out a grid first then located your track? can you elaborate on some of your methods i know some but whould like to know what and how u used some of that equipment? its been a long time for me and even though some is obvious.
did you locate your striaght tracks first? then drew in your radious? or did you make templates from card board?
i was planing on making all my curves from flex track
i would use this kinda method correct?
modeltrains.about.com/od/DRGW-Benchwork/ss/Laying-Out-The-Subroadbed-For-The-Project-Layout_3.htm
i was planing on setting up my yard first , it would use the edge and grids as a guide. then make the rest of the track and go out from there. i have only gone thru half of the cad railbook example i only needed to fit an idea onto a area i have to work and fit certain radii . i know u can put easements into your layout but i didnot yet. i was wondering if the curves i have made i can now add the easement into it or should i be doing this another way.or should i do it on cad?
also any article would be good too if its too lenghty to explain i can do my homework too obviously.
thanks
o btw how steep are your grades on that? thats tight to make that loop around and under? cool looking layout.
thanks
- jrb
13 years 7 months ago - 13 years 7 months ago #15219
by jrb
Thanks, being a table my wife and daughter bought I couldn’t make mods and the space is a bit limited.
The curves and switches are Marklin “sectional” ( www.guidetozscale.com/html/marklin_track.html ); the longer straight portions are Peco flex.
IIRC the grades are 3.5 & 3% -- the circle/helix @ 3.5 w/8510s. Parallel curves are 8520s & 8530s.
I did my Track Planning using several different methods/tools, and finally using Any Rail ( www.anyrail.com/index_en.html ). Also looked at lots of other pictures and plans.
After that I imported the Any Rail file into Train Player ( www.trainplayer.com/ ); which let me Run trains to make sure it was what I wanted.
With the scaled plan from Any Rail I then laid out the parallel corner leadig to the cross over switches & helix w/siding switch.
Tools that helped: T-Square, ruler (w/radii holes), track & other templates.
Here’s a thread for my Coffee Table Layout: www.zcentralstation.com/index.php?option=com_kunena&func=view&catid=2&id=12928&Itemid=212#12950 .
Hope this helps a bit.
Time to create page: 0.198 seconds
