- Thank you received: 5
Door slab layout
- TheWag
14 years 10 months ago - 14 years 10 months ago #12127
by TheWag
Door slab layout was created by TheWag
My door slab layout made it's public debut today at local train show. Thought I'd share it here too. I've been working on this layout for about a year. Slowly getting further. I'm working on the yard side now and learning a lot (like be careful with hyrdocal!) Below is a picture from today's show. More pictures and info at
my website
- ztrack
- Thank you received: 192
14 years 10 months ago #12128
by ztrack
Replied by ztrack on topic Re: Door slab layout
The layout is looking great! You are off to a good start.
You mentioned you are using hydrocal. Are you using the hydrocal for the scenery? If so, you may went to look at a product called Celluclay. I love the stuff. It is a mix of plaster/clay like binder and paper. It goes on like plaster, but is extremely light weight when it dries. It can be carved and cut once it dries. It is not brittle like plaster. If the layout is portable, the Celluclay will definitely give you a huge weight savings.
Here is an image of wet celluclay over a foam base:
I purchase it a craft stores.
- TheWag
14 years 10 months ago #12129
by TheWag
Replied by TheWag on topic Re: Door slab layout
Thanks Rob, I'll have to look into that....
14 years 10 months ago #12130
Replied by Socalz44 on topic Re: Door slab layout
Good one Rob. I wonder if it is at Micheal's? I will check this out as well. Is this like the stuff Loren uses? I can remember the name right now. Jim
- ztrack
14 years 10 months ago #12135
by ztrack
Yes I get mine at Michaels. It comes in a square, rectangular bag. You can actually see the fine bits of newspaper in it. I put a little water in a containers, then add the Celluclay. I keep adding, and mixing until I get a thick, yet creamy mixture. If you still have water in the bowl, add a bit more of the Celluclay. It does shrink a little when it dries, but not too bad. I typically do a little touch after it dries to fill in a spots that shrink.
14 years 10 months ago #12145
Thanks Rob, I will get some. Jim
Time to create page: 0.244 seconds
