Cement Factory
17 years 4 months ago #5530 by Mr. White
Cement Factory was created by Mr. White
So I have decided to put a cement factory on my layout. I have found some good reference material here: www.lehighnw.com/canada/PlantTour/PlantTour.htm#10 and I have started building the preheater tower. Here is my pattern that I am using based on the preheater in the link. I selectivly compressed it because at scale it would stand 10.5 inches high, i took it down to six and took out a window here and there. I am repeating this pattern on all four sides and adding the embellishments to the outside and I hope to slip this frame over a pipework maze inside.
I used red for the actualy frame so I could see it better when I am cutting it out of styrene.
17 years 4 months ago - 17 years 4 months ago #5531 by Mr. White
Replied by Mr. White on topic Re:Cement Factory
Here is the frame of the preheater it will slide over all of the detail work inside
17 years 4 months ago #5532 by Mr. White
A picture with the engine next to it for scale, the structure is 6 inches tall
17 years 4 months ago - 17 years 4 months ago #5533 by Socalz44
Replied by Socalz44 on topic Re:Cement Factory
Zac, Nice job. That is about 100z ft. It is not going to look out of place or over bearing on your layout is it? For the most part a key to layout enjoyment is trains, and scenery. Buildings shouldn't become the focal point of the the layout. Of course this is your layout and you can do what ever you wish. If it was me, at the very least I would eliminate the top floor. Unless you are trying to be faithful to the prototype, I think this is the way to go. Who will know the difference in the end? I know you have compressed it, but to my eye is still looks a bit tall. m2cw Cheers, Jim CCRR:)
17 years 4 months ago #5534 by Beverly56
Replied by Beverly56 on topic Re:Cement Factory
Zac,
That's a HUGE plant! We have a cement plant in the west end of our city. It absolulety dwarfs everything around it. Such a plant would definitely be the focal point of your layout. Good work with the styrene :)
17 years 4 months ago #5535 by andyjbj
Replied by andyjbj on topic Re:Cement Factory
sounds like the enormous size is appropriate. Definitely some bldgs scale very large in Z.
17 years 4 months ago #5536 by Mr. White
I did a lot of thinking about size. The scale size if I were to do prototype would be 10.5 inches high. Since my tallest "mountain" in the back is only 24 inches high that would have been a little awkward and the rest of the building would have taken up 3 ft of linear space (my whole layout.) at 6" though i think that it will be a nice contrast between man made structures and natural made beauty. Also I am going to light it up with a ton of fiber optics to almost make it the focal point of the track when the lights are off. I just think the architecture will throw some nice shadows and give my track a more prototype appearance.
17 years 4 months ago #5537 by Mr. White
Here is my crusher mill base, I need to get to the hobby store to get some more styrene like ladders and railing and such. Oh and a lot of pipes.
  • Alaska Railroader
  • Premium Member
  • Premium Member
17 years 4 months ago #5544 by Alaska Railroader
Replied by Alaska Railroader on topic Re:Cement Factory
I think you are doing a fantastic job, I like the height also.
17 years 4 months ago #5547 by ausman2001
Replied by ausman2001 on topic Re:Cement Factory
Good job Zac. Things like the height of structures, in relation to their surroundings, is very much a matter of personal aesthetics, but from my perspective I think you're on the right track. Maybe you might consider having nearby structures or geopgraphical formations gradually stepping down from the height of your cement works, just so that it doesn't look quite so stark.
Time to create page: 0.244 seconds
