DCC and Lights
11 years 3 weeks ago #17944 by zbarr474
DCC and Lights was created by zbarr474
Not really Scratch Building -- but....
If you change an AZL motor board to a DCC board, such as an E8, the lights (LED's) on the DCC Board are nowhere near the light hole(s) on the engine shell. I tried using some acrylic cylinders to funnel the light to the opening. Poor success as you have to somehow attach the cylinder to both the shell and the chassis. I don't see an easy or practical way to connect each end.
Has anyone solved this problem?
...don
11 years 3 weeks ago #17945 by shamoo737
Replied by shamoo737 on topic DCC and Lights
There's two ways to skin the cat. Either change the smd with a regular led with longer pins, or use fiber optics to extend it all the way to the smds.
11 years 3 weeks ago #17946 by shamoo737
11 years 3 weeks ago - 11 years 3 weeks ago #17947 by zbarr474
Replied by zbarr474 on topic DCC and Lights
I'll look into this and see what I am getting into. I'd like not to mess up a DCC board nor a chassis. I am not at home at the moment, so when I get back I'll see what I can do.
One obvious question is can I reverse the LED polarity without doing any damage. Also, should the existing LED be removed or just left in parallel the new DCC LED.
Many thanks.
...don
Time to create page: 0.209 seconds
