- Thank you received: 73
I didn't know this??
- Kelley
13 years 10 months ago #14896
by Kelley
I didn't know this?? was created by Kelley
So there I was, with those cool new gondola kit I got from Gerd. I was thinking, Hmmm, If I used some of those supper magnets, I could hold this sucker together in all the right angles and with no hands, and could then concentrate on putting just enough glue where I need to.
The only one I did find was the round one,
(The other tiny,tiny square ones are lost in the vortex, probably sucked up in my computer's hard drive,vacuum motor, or it was ingested.) Anyways I took the one I had, and thought, OH BOY,I will get these 2 pieces to stick soooo close together, and then I found out...stainless steel is non magnetic
- rvn2001
- Thank you received: 72
13 years 10 months ago #14897
by rvn2001
Replied by rvn2001 on topic Re: I didn't know this??
We all learn something new every day.....some of it is disappointing.
- Gerd
- Thank you received: 38
13 years 10 months ago #14901
by Gerd
Replied by Gerd on topic Re: I didn't know this??
Kelley, it's actually nickel-silver, but that doesn't help, correct, non-magnetic. As an aid just use something L-shaped and stick the parts on with some sticky tape. I do the same, I have a Teflon block and solder those parts on them too.
- Kelley
13 years 10 months ago #14902
by Kelley
Replied by Kelley on topic Re: I didn't know this??
Thanks Gerd. Absolutely no negative reflection on the model as all. jut my magnet idea. I'm using and clothespins and rubber bands and tape legos and...the usual stuff.
Time to create page: 0.794 seconds
