Wood Trestle Bridge
14 years 1 month ago #14350 by southernnscale
Wood Trestle Bridge was created by southernnscale
I'm working on wood trestle bridge. Is there any place to get information on real timber trestle bridges and how they where built. The bents seem easy but the deck area where the track is layed,
to find sizes of wood used?
14 years 1 month ago #14354 by markm
Replied by markm on topic Re: Wood Trestle Bridge
Hi,
Model Railroad Magazine has a book that covers dimensions for wood trestle bridges (as well as others). A while back they were offering it as an e-book. The deck area is generally a number of timbers between the bents that support the ties, which are typically laid at half the spacing.
There is also at least one laser kit available.
14 years 1 month ago #14391 by Socalz44
Replied by Socalz44 on topic Re: Wood Trestle Bridge
You might try the 'bible' of bridge building: books.google.com/books?id=NZEOAAAAYAAJ Jim
14 years 1 month ago - 14 years 1 month ago #14489 by smholt
Replied by smholt on topic Re: Wood Trestle Bridge
Black Bear Con Comp has some info that can be used, even if you want to build a trestle from scratch:
www.blackbearcc.com/tjk_6lho.htm
On this page 2 drawings can be downloaded, that give you typical dimensions:
www.blackbearcc.com/drawings/sixlegdwg_p1.pdf
www.blackbearcc.com/drawings/sixlegdwg_p2.pdf
I used info from here to create my own trestle from scratch on my new Zmod module:
www.platelayer.com/silver-creek-zmod-layout-2.aspx
The following user(s) said Thank You: southernnscale, stonysmith
Time to create page: 1.323 seconds
