Found some 3D freeware
14 years 3 months ago #14081 by Kelley
Found some 3D freeware was created by Kelley
Stumbled across this . I am going to try and use it to learn how to make 3d drawings, if possible. Might be a good start.
www.3dvinci.net/PDFs/GettingStartedInTinkercad.pdf
14 years 3 months ago - 14 years 3 months ago #14082 by stonysmith
Replied by stonysmith on topic Re: Found some 3D freeware
Check this blog entry:
www.shapeways.com/blog/archives/1551-3D-Printed-Brewster-Station-Pushing-the-Limits-of-Browser-Based-3D-Modeling.html
The girl that created this station used Tinkercad (mentioned above by Kelley).
She modelled each brick INDIVIDUALLY!!!... a bit more work than most would want to perform.
Too bad it's an HO scale model.
FYI.. Tinkercad requires the Chrome or Firefox browsers.. it won't work with any Microsoft browser.
14 years 3 months ago - 14 years 3 months ago #14095 by officialchicken
Replied by officialchicken on topic Re: Found some 3D freeware
I've heard of tinkercad, but never used it. I've only used the big expensive ones like solidworks, autocad, rhino, etc.
Check out sketchup, you can grab (or place) any 3d building in google earth to get started. There are already quite a few (and by that I'd guess millions) of interesting 3d buildings in google earth, if you weren't aware. It's extremely simple to learn CAD, without mucking about with CAD. And it doesn't require google earth, but that is the worlds largest architectural building model library that I'm aware of. I've used it with laser-cut and 3d printed models too, it works just fine.
www.sketchup.com/intl/en/index.html
14 years 3 months ago #14099 by N/A
Replied by N/A on topic Re: Found some 3D freeware
Wow!! That is a huge step forward for 3D printing!!
14 years 3 months ago #14111 by Kelley
Replied by Kelley on topic Re: Found some 3D freeware
My problem is trying to center 2 items together, re-sizing anything round, and figuring out how to step up and down the sizes..19.5..oops..10.5..oops..19.5...
It does not help using the old computer where you move the mouse and it takes about 2 seconds to react.
Still I am plugging away at it and I hope II can make something someday.
14 years 3 months ago - 14 years 3 months ago #14222 by southernnscale
Replied by southernnscale on topic Re: Found some 3D freeware
Have you tried GMAX ? It's a free software program almost like 3D Max. You can make 3D models on it and it has alot more.
14 years 3 months ago #14224 by David K. Smith
Replied by David K. Smith on topic Re: Found some 3D freeware
Kelley wrote: My problem is trying to center 2 items together, re-sizing anything round, and figuring out how to step up and down the sizes..19.5..oops..10.5..oops..19.5...
Google SketchUp can help in this regard because you can simply type the dimension you desire while moving the mouse--it doesn't care how far you move the mouse, it follows the typed command and makes the desired numerical adjustment with perfect accuracy.
14 years 3 months ago - 14 years 3 months ago #14226 by Zcratchman_Joe
Replied by Zcratchman_Joe on topic Re: Found some 3D freeware
Kelley wrote: It does not help using the old computer where you move the mouse and it takes about 2 seconds to react.
Kelly, mouse lag isn’t due to the age of the computer; it’s due to the amount of available memory. Over the years, we always add a few new programs here and there that run in the background (and some that only keep watch in the background)… our favorite programs get larger and larger with each update, plus Windows itself gets bigger with each update. This all takes a toll on memory usage. If you could boost the memory (VERY cheap compared to a newer computer), I’d venture to say your mouse would catch up with your hand!
This, of course is assuming your computer is running properly. Sometimes simply reinstalling Windows and then only the programs you actually still use will do the trick.
Time to create page: 2.355 seconds
