- Thank you received: 73
Wow look at this monster traincar!!!!!!
- Kelley
14 years 8 months ago #13216
by Kelley
Wow look at this monster traincar!!!!!! was created by Kelley
I just found this at Marsilus Trains newsletter..its on the bottom www.n-trains.de/news/1203back.pdf
If I was doing modern trains I would be itching for one of these things.
www.railpictures.net/viewphoto.php?id=364930&nseq=1
The newsletter says he will have one at Altenbeken to show.
- stonysmith
- Thank you received: 175
14 years 8 months ago #13217
by stonysmith
Replied by stonysmith on topic Re: Wow look at this monster traincar!!!!!!
14 years 8 months ago - 14 years 8 months ago #13226
Replied by garthah on topic Re: Wow look at this monster traincar!!!!!!
- southernnscale
- Thank you received: 188
14 years 1 month ago - 14 years 1 month ago #14352
by southernnscale
Replied by southernnscale on topic Re: Wow look at this monster traincar!!!!!!
do you have the Auran Trainz Program TS2009 or TS2012 ? If you do there is one like this not the same but its in the rolling stock in the program and it has several section to it. Its has 12 pieces to construct it.
- kevsmith
- Thank you received: 55
9 years 11 months ago #18198
by kevsmith
Replied by kevsmith on topic Re: Wow look at this monster traincar!!!!!!
Well funny enough I have some of these at work. My team maintain six of these beasts designated KXA-C on TOPS
Fully loaded they top out at 166 tonne
With two bogies under each span bolster they'll go round a curve as tight as a dinner plate!
The previous versions were noted for being clad in stainless steel which upped the tare weight quite a bit. The new versions are stripped right down to get the payload as high as possible
Kev
Kev
- southernnscale
9 years 11 months ago #18199
by southernnscale
- southernnscale
9 years 11 months ago #18200
by southernnscale
9 years 11 months ago #18201
Instead of trying to build span bolster in RP build a a shell to fit over either bar stock of Brass or Evergreen styrene as both can be drilled and tapped in addition the use of brass wire and rod can be used with either to enhance your detail
Time to create page: 0.242 seconds
