- Thank you received: 73
Heating Oil Tanks
- Kelley
15 years 1 month ago - 15 years 1 month ago #11793
by Kelley
Heating Oil Tanks was created by Kelley
- shamoo737
- Thank you received: 30
15 years 1 month ago #11794
by shamoo737
Replied by shamoo737 on topic Re: Heating Oil Tanks
Kelley, I have seen something like that on ebay.
- Kelley
15 years 1 month ago #11797
by Kelley
Replied by Kelley on topic Re: Heating Oil Tanks
I am thinking there are people like myself who donot go on Ebay. Is this somthing that is on Ebay all the time?
- N/A
- Thank you received: 27
15 years 1 month ago #11802
by N/A
Replied by N/A on topic Re: Heating Oil Tanks
Kelley,
GC Laser makes one just like that in kit form: www.zscalemonster.com/gclaser/detail/gcl-5104.jpg
- Kelley
15 years 1 month ago #11807
by Kelley
Cool..That will go on my short list stuff I need..it looks great.
- Zcratchman_Joe
- Thank you received: 41
15 years 1 month ago #11809
by Zcratchman_Joe
Replied by Zcratchman_Joe on topic Re: Heating Oil Tanks
Kelly,
I've found they're very easy to make from soft wood. It's very easy to round off the top and bottom of a retangular piece of wood and then cut it to length. I use cut-to-length straight pins as legs and that way the head of the pin gives a little bit of a base for the leg to stand on and the point of the pin is easy to push into the soft wood. Or if the look of that doesn't appeal to one, the heads can just be snipped off. The snipped off heads also make a good filler cap to the tank. And for more detail, just a little piece of straight pin can also be used as the fuel gauge that sticks up from the tank. A bit of small wire glued to the bottom of the tank can then be used to run the fuel to the house or what have you. The only problem I've found is that sometimes the side of the tank wants to push out some when sticking in the pins. The thinner the straint pins (like silk pins or even thinner), the better. Should be a breeze for you Kelly!
Time to create page: 0.416 seconds
