GM Fishbowl Bus
16 years 1 week ago #10033 by stonysmith
GM Fishbowl Bus was created by stonysmith
Since several people have requested it, I decided to attempt modelling a GM Fisbowl Bus.
It is now available for sale thru my Shapeways shop:
www.shapeways.com/model/176128/gm_fishbowl_bus___z_scale.html?gid=ug4375
If you don't know about Rapid Prototyping, please check this forum entry
Attached below are several camera angles.
Many thanks to John Bartolo for the prodding encouragement and advice while I was developing this model.
Here's what we were trying to build:
A bit of history about the bus:
en.wikipedia.org/wiki/GM_New_Look_bus
Here is the reference picture I used for measurements:
And my final results:
16 years 1 week ago #10034 by N/A
Replied by N/A on topic Re: GM Fishbowl Bus
Stony,
FANTASTIC!!! Kick butt dude! Thank you SOOOO much for doing these. They look great!
All the best.
16 years 1 week ago #10036 by smholt
Replied by smholt on topic Re: GM Fishbowl Bus
Do you have any pictures of the "real" finished model and not only pictures of the computermodels?
16 years 1 week ago #10038 by stonysmith
Replied by stonysmith on topic Re: GM Fishbowl Bus
I have not ordered any of them just yet. I like to pass around the computer photos one last time to see if anyone has any comments/suggestions before I go ordering them.
To get a good idea of what the finished models of this type look like, take a look here.
Stone Bridge Models
16 years 1 week ago #10040 by smholt
OK, so you have not your own "Prototype Printer", so you also must wait for the final result. :-)
  • Alaska Railroader
  • Premium Member
  • Premium Member
16 years 1 week ago #10041 by Alaska Railroader
Replied by Alaska Railroader on topic Re: GM Fishbowl Bus
Svein,
The photos on Anthony's site are older and not updated. Here is the most recent RP model I got and how it turned out after painting and some painstaking decal work:
Stony's computer rendering and then my first attempt with one...
  • Alaska Railroader
  • Premium Member
  • Premium Member
16 years 1 week ago #10042 by Alaska Railroader
They aren't going to look like diecast or resin cast but they are very nice considering what we normally do NOT have available in Z. Stony has done a great job.
hope this helped,
Karin
16 years 6 days ago #10043 by smholt
Looking great. Thank you for the picture. I am only curious, because I haven't been looking much at this before in Z-scale.
16 years 6 days ago #10044 by stonysmith
uh.. Ooops.. the back axle only had two tires..
The model has been updated to include all four.
Thanks to Fred Ladd for pointing that out.
16 years 6 days ago #10045 by Mattias
Replied by Mattias on topic Re: GM Fishbowl Bus
Looks really great. I already have a couple of your models. Just a few questions. On the shapeways-site, it tells Height 1.1cm and depth 1.4 cm. Is this just mixed up on Shapeways? And, is the model completely closed or is the bottom or the windows open?
Mattias
16 years 6 days ago #10046 by stonysmith
Thanks Mattias, glad you like it/them. The Shapeways site has an oddity when you upload models.. it decides what orientation it likes best. I think it turns things so they can be as tall as possible. If you look thru my shop, you'll even see some things standing on their nose! :laugh:
That's also why you get the rear-view of so many models instead of front view.. it's their upload software. But it doesn't make any difference to the printing. They could even be printed upside-down and still come out the same.
The doos/windows are closed. There is a "void" inside the model, and two small holes on the very bottom that allow access to the void (think about putting lights in there), but the inner walls do not accurately model the walls of the real bus. It's just a big old cube inside. The reason for the void is to reduce the amount of plastic used, and therefore drop the cost of the model by about half.
Shapeways has a minimum thickness limit of 1mm, which at Z scale is 9 inches. If I wanted to "open the windows", I'd have to make all the support struts a minimum of 9 inches wide, and on the real bus, they're about TWO inches wide. It'd distort the look of the bus pretty badly to try to get around the 9 inch limit.
16 years 6 days ago #10047 by Mattias
Thanks for your detailed reply. That makes sense if the material is too thick for such a small detail.
Mattias
16 years 5 days ago #10049 by JamesTraction
Replied by JamesTraction on topic Re: GM Fishbowl Bus
Stony,
what drawing package are you using for your 3D models for importing to shapeways?
I just ordered some of your items so I can see what the finish is before I try my hand at it.
-James
16 years 5 days ago #10050 by JamesTraction
Oops, just read your link at the top of this thread. Got the info.
-James
16 years 5 days ago #10051 by stonysmith
I would suggest that you try to find TrueSpace 7.6 rather than 7.6.1. There were some features taken out of the 7.6.1 that are helpful for dealing with Shapeways models.
Contact me if you need help getting started. I'll be more than willing to help.
Time to create page: 1.192 seconds
