- Thank you received: 188
50ft Gondola's
- southernnscale
10 years 5 months ago #18113
by southernnscale
50ft Gondola's was created by southernnscale
Hello! Here is an interesting piece 3D printed Gondola's normal side 5ft tall 50ft long in Z scale same as the MTL gondola's. This is a 3D printed insert that will bring the side up to a 12ft high Photo's attached!
shpws.me/MfFm
shpws.me/MfFm
The following user(s) said Thank You: garthah, lokie62
- southernnscale
10 years 5 months ago - 10 years 5 months ago #18118
by southernnscale
Replied by southernnscale on topic Taylor Reachstacker w/winkle coil grabber
This unit is the Taylor Reachstacker with the Winkle Coil Grabber attachment. attachment swivels
shpws.me/McA5
shpws.me/McA5
- southernnscale
10 years 5 months ago #18119
by southernnscale
Replied by southernnscale on topic 50ft Gondola's
Added a set of Taylor TS 9972 reachstacker with the winkle coil grabber one with boom up and one with boom down. the boom has two section and it seem That shapeways when using the wax to support material gets into the inside and makes it hard to get it to move or slide all other movable pieces work except for boom. I may have to soak it longer to get the wax soften enough to be removed. But until I can solve the problem I did two of them one for loading with boom up!
Time to create page: 0.471 seconds
