- Thank you received: 16
Introducing two new Z scale models
- kmalkowski
13 years 6 months ago - 13 years 6 months ago #15619
by kmalkowski
Introducing two new Z scale models was created by kmalkowski
I would like to introduce two new models into the world of Z scale, the Counterweights used for tensing switch and signal cables (Weichenspannwerk and Signalspannwerk respectively). If you are not familiar with European railroads, here's brief explanation. European signals and switched (at least ones switched manually) are controlled through a set of cables. The counterweights are used to ensure that the cables maintain tension.
The models are available through Shapeways.
If you are looking to add details to your European themed Z scale layout check them out at:
shpws.me/nLNf
shpws.me/nLN7
If you decide that you do like them, you can order them from Shapeways.
Personally, I must admit that designing these two was a lot of fun
shpws.me/nLNf
shpws.me/nLN7
The following user(s) said Thank You: southernnscale, Mr.JA, stonysmith
- kmalkowski
13 years 6 months ago #15628
by kmalkowski
Replied by kmalkowski on topic Re: Introducing two new Z scale models
Now also available in groups of 4 at:
www.shapeways.com/shops/zscaletracks
Time to create page: 0.192 seconds
