Flow problems
16 years 8 months ago #8293 by sky_68
Flow problems was created by sky_68
Hallo to all,
I've a little problem, I hope it's little.
I have a starter kit Marklin 81562 with the loco BR74. I make my first layout, but I see that the loco doesn't run smoothly. If it go slowly it stops at some point of the track.It seems it lose the contact with the rails.This appens only because the rails are not perfectly flat?
Thaks:(
16 years 8 months ago #8295 by ztrack
Replied by ztrack on topic Re:Flow problems
If the locomotive is stalling or hesitating in the same spot on the track, likely this is a track issue. What I would do is first clean the tracks with a soft cloth and rubbing alcohol (isopropyl). Also, clean the loco wheels. If the problem goes away, it was just dirty track. If the problem continues, it is time to do some track work. Level track is very important. Some locos can handle non-perfect track better than others so it is not uncommon to have no problems until a new locomotive class is introduced.
In may case, even the slightest dip in the track can cause a loss of contact. I have used shims under the track to level it. I also keep a piece of card stock and thin pieces of wood around the layout for just this purpose.
Also, over time, dips can appear. As you clean the track, the pressure applied can cause track to dip if the roadbed is not firm. I also find that track that is secure causes less problems than track just laying on the roadbed. Even temporally holding the track down can make a big difference.
Other tips, I do use Gaugemaster track cleaners on my layout. These do keep the trains going, even with dirty track.
Remember, locos and rolling stock are only as good as your track work.
16 years 8 months ago #8304 by sky_68
Replied by sky_68 on topic Re:Flow problems
Thanks Rob,
in effects I had some dips on my track. I'm working hard to perfect level all the track.
Paolo
16 years 8 months ago #8310 by ztrack
Paolo,
Those dips will do it! Let us know the result once you level the track. I am sure you will be much happier.
Time to create page: 0.427 seconds
