cleaning loco
16 years 9 months ago #7953 by charles
cleaning loco was created by charles
Hello,
Is there some special advice to clean my loco? :huh: I have two steamer and one F7A from Markin.:cheer:
Thank you :) Charles
16 years 9 months ago - 16 years 9 months ago #7957 by Havoc
Replied by Havoc on topic Re:cleaning loco
Careful and keep all pieces :blink:
Seriously, take them apart and clean each piece. then when putting them together oil a little bit. If this is the first time you do it, then try one or all of the following:
- get a set of tools before you strip the first screw of its head: small screwdriver and tweezers
- put a white (or similar) coloured towel on your desk, working inside a light coloured box is another option
- take photo's and notes at each step
- try to get one of those large egg cartons and put the pieces of each step in a cavity
I use an old film canister with some alcohol for degreasing the metal parts. I never clean the plastic ones.
When taking apart marklin bogie engines, keep the gears of each bogie together. Be very careful when taking the bogie apart as the spring that makes the coupler work is very small and impossible to find if it jumps away (the towel/box might help). This happens when you unscrew the single screw at the bottom of the bogie and pulls the plastic outside frame of the metal inner one.
I use the oil from Marklin, a bottle lasts a loooong time. Don't apply directly from the bottle as you'll use too much. Wet the top of a needle with it and apply that. A few ticks against the large gear and a single one on each gear is enough. Don't get any on the wheels.
16 years 9 months ago #7958 by Beverly56
Replied by Beverly56 on topic Re:cleaning loco
Charles,
Here's a YouTube video that shows taking apart a Marklin 8864 that might be helpful :)
16 years 9 months ago #7959 by shamoo737
Replied by shamoo737 on topic Re:cleaning loco
charles wrote:
Hello,
Charles, whatever you do, dont take the gears out of the steamer. Its hard for a beginner to put it back together. I find electronic motor cleaners for RC clean better then alcohol. Like Havoc said, put everything in containers. Its very easy lose those small part.
16 years 9 months ago #8016 by xj700
Replied by xj700 on topic Re:cleaning loco
shamoo737 wrote:
I'll also add that the electronic parts cleaner you can get from Radio Shack is another good one to use. I find it useful for cleaning (in addition to the motor brushes) the contacts that rub on the wheels on your loco. Take care not to get any cleaner on bare skin. I think it has acetone in it.
16 years 9 months ago #8024 by ausman2001
Replied by ausman2001 on topic Re:cleaning loco
Welcome to the forum charles. Another little hint: if you take the trucks off your F7A, make sure you put them back the same way. If you reverse them the loco will run in the reverse direction to what you expect when you apply power to it. Why this is so I don't know, but it certainly applies to all Marklin locos with trucks (ie diesels and electrics).
16 years 9 months ago - 16 years 9 months ago #8026 by David K. Smith
Replied by David K. Smith on topic Re:cleaning loco
I can assure you that flipping or swapping the trucks on a Micro-Trains locomotive will not reverse the direction of travel. The only thing that can do that is removing the motor and reinstalling it reversed. While I don't have direct experience with Märklin locomotives, I suspect the same holds true.
16 years 9 months ago #8027 by shamoo737
David, I agree on the MTLs, but If you switch the trucks on the Marklins, they do run on reverse position.
16 years 9 months ago #8028 by David K. Smith
Interesting! I'd love to learn more about why this is so. They must have a very unusual power transfer system. Any chance of some photos?
16 years 9 months ago #8045 by shamoo737
David, I know it sounds strange, but its true. Look under train runs backward.
www.zscale.org/articles/revival.html
16 years 9 months ago #8046 by agarpin
Replied by agarpin on topic Re:cleaning loco
David K. Smith wrote:
... They must have a very unusual power transfer system. Any chance of some photos?
Thr trucks are not identical but symmetric.
The change in position is the polarity is reversed (in DC analog control only)
lh6.ggpht.com/_qh55JF4fIC4/S3nWkVu_B_I/AAAAAAAABrc/TvOljC0GdE0/88444%2011.jpg
lh3.ggpht.com/_qh55JF4fIC4/S3nWmS7oeUI/AAAAAAAABrg/7Qdt5o1b6OA/88444%2012.jpg
Greetings from Spain
agp-schwarzwaldbahn.blogspot.com
www.escala-z.com/forum.htm
16 years 9 months ago #8047 by David K. Smith
Thank you very much for posting this! Now I understand what's going on.
Time to create page: 0.815 seconds
