Wiring 22 or 24 gauge?
17 years 8 months ago #3076 by TerryH
Wiring 22 or 24 gauge? was created by TerryH
I was just reading an article about potential fire hazard using 24 gauge wire, even with a 3A source if dead shorted. I am using 8A, they recommended using 22 gauge. I didn't get to finishing reading the article due to a power failure. Now that the power is back, I can not find the article. :(
So my question is a simple one, what wire should I be using for control tracks, switches and DC LEDs? And where can I buy some, possibly in Canada.
17 years 8 months ago #3077 by Socalz44
Replied by Socalz44 on topic Re:Wiring 22 or 24 gauge?
Terry, Personally I'm a member of the bigger is better club. If presented with a choice I always use bigger wire. From the power pack to the track I use 20 gauge solid wire. Maybe overkill but never a wiring issue. For lighting buildings and such I use 22 gauge stranded wire from a buss bar. From the powerpack to the buss bar 20 gauge solid. M2CW. Cheers, Jim CCRR:)
17 years 8 months ago #3078 by TerryH
Replied by TerryH on topic Re:Wiring 22 or 24 gauge?
Jim, thanks for the info. What type of coating on the wire, does it matter? I want to but two 500 foot rolls, one black and one red. Can you suggest a site? I am having problems finding it. I think I prefer 20 gauge all around also.
17 years 8 months ago #3079 by Socalz44
Terry, Yes, standard plastic coating is required. I get all my wire at Radio Shack. Most big box stores don't carry wire that small. A search on Google should produce results showing wire availabilty for shipping Down East. Cheers, Jim CCRR
17 years 8 months ago #3080 by zthek
Replied by zthek on topic Re:Wiring 22 or 24 gauge?
I am using 8A,
8A? Where? Can you clarify?
Lajos:unsure:
17 years 8 months ago #3081 by zmon
Replied by zmon on topic Re:Wiring 22 or 24 gauge?
Fellas, here's a little bit of what i know about wire and electronics. On DC systems (like your car) its common practice to use braded wires in the apropriate gauge to cover your load. On AC systems (like your house) its common practice to use solid copper wire, again in the apropriated gauge to cover your load.
With regards to train sets, DC systems (those that use transformers) should be wired with braded wire to compensate for voltage drop over longer runs, and to more eficently carry the weaker DC power. On DCC layouts its advised to use solid copper wire for Buss runs as well as track feeder wires given that DCC systems opperate on AC voltage.
From what i've be told, DC power is weaker and has more resistance (thus voltage drop) and benifits by the multi stands in braded wire to carry its power with the least amount of drop. Conversly with AC voltage, it is in a sine wave and prefers to travel in a single conductor wire to maintain its sine wave over greater distances.
Practicality with Z scale; The reality is that none of the locos or powered devices that are commercially available for Z scale consume large amounts of amperage (power), so wire sizing is simplified. Additionally, given the small size of most Z scale layouts, the runs of wire are not long enough to have much if any decernable voltage drop, so again wire sizing is simplified. Wire size charts that use voltage and load (amperage) are available on the internet for folks that want to really get down to particulars. 20-22 gauge braded wire should be more that sufficent on most DC Z scale layouts. Marklin sells a full line of their recomended wire in all the colors needed to follow their wiring system, and i think its 22 gauge. On DCC i was recomeded to use (and followed on my modules) 14-16 guage single conductor wire for buss runs and 20-22 gauge single conductor for track drop feeders. A good source for single condutor wire is Home Depot or Lowes type store. You can buy rolls of the 14 or 16 guage, and the 22 gauge feeders can be stripped out of CAT-type comunications wire. CAT wire comes in numbers from 2-12 and this simply corolates to the number of pairs of wires in the cable. Remove the outer jacket, and the colored pairs of wire are inside, and jacketed. I use CAT-5 myself so i have five colored pairs of wires to chose from when i strip them out..
Hope this helps folks out, and please add any information that i missed, or correct me if i stated something wrong...:side:
Tony B...
Wasatch Z ClubB)
17 years 8 months ago #3084 by TerryH
Tony, thank you very much for the info. I ordered two rolls of stranded wire.
17 years 8 months ago #3089 by Havoc
Replied by Havoc on topic Re:Wiring 22 or 24 gauge?
Euh??? Please brush up your elementary electricity before putting such things on a forum.
The choice for stranded or solid wire has nothing to do with AC or DC. It has all to do with metallic section, resistance and flexibility. In your car the wire has to be bended quite a lot and has to resist vibration and adjust to large temperature variations hence they use stranded wire as it is far more flexible. In your house you need the maximum of copper in a given section and as the wire is once installed and never moved they use solid wire as for the same overal diameter a solid wire has more copper than a stranded one. Also the used termination, screw termination like in the wiring of your house is more reliable with solid wire.
The power of AC or DC is the same: 1W is 1W. It doesn't matter for electricity what wire it uses as long as we're talking about power wiring, antennas are a different issue. The voltage drop over a wire (resistor) is the same for AC as for DC: V= IxR.
The distance issue with DC has to do with the ability to change the voltage. In very long runs the resistance of the wire becomes important. Now for power distribution you don't want loss. So for a given power, if you use a higher voltage you have less current, so you have less voltage drop and less loss. Now to make a higher voltage (and reduce it later) is far easier with AC because you can use transformers. There are a few complications but those can be discarded here (unless you're into 300kV lines over a few 100km). That's the main reason they use AC in power transmission: it is easier to change the voltage up/down and take advantage of that.
This is a good system. Use a bus that follows your main track using wire like for your house wiring (easy to find and reasonably cheap), then from there smaller feeders. CAT-5 would be my choice as well: easy to find, cheap and easy to work with. But take apart such a cable and you will see that there are only 4 pairs in it! The numbers stand for the performance of the cable in terms of bandwidth.
17 years 8 months ago #3090 by TerryH
Havoc, thanks for the info. I will use bus wires. I have already purchased 20 gauge stranded wire, so i'll live with that. All of the Marklin track and switches have stranded wire, but the wire they sell is solid core. I measured it at 24 gauge but could be wrong. I think I will be safe using the stranded wire for track and switches. I am a little concerned about using it on my DC LEDs. 12V and I have a seperate power adapter for them which will support 50 of the 1.8mm type.
17 years 8 months ago #3091 by SJ-BAZ-man
Replied by SJ-BAZ-man on topic Re:Wiring 22 or 24 gauge?
Terry, you'll be fine with any of that wire with Z. I won't go into all the technicals, Tony and Havoc have pretty much covered that.
If you truly have an 8 Amp supply, I assume it is DCC. If so, the supply will protect itself in ~0.5 seconds, repeatedly so there really isn't a power dissipation issue.
If you are using an O or G scale 8 Amp DC power pack, I would recommend either changing to an appropriate lower current Z or N power pack (pick ANY one) or, use it as a voltage source for a smaller hand-held self limiting controller like a Ztek or Joerger that will give you much better DC speed control.
17 years 8 months ago #3093 by TerryH
Jeff, I have three Marklin 67271 transformers. Input 120VAC 60HZ, Outputs 0-10V DC 8VA and 10V AC 8VA. Maybe I am incorrectly assuming a VA is an amp. Anyways they came with the Marklin sets, so I don't think there will be any problems. Thank you for responding.
17 years 8 months ago #3098 by Todd
Replied by Todd on topic Re:Wiring 22 or 24 gauge?
Terry,
The VA thing can be confusing, but thats how they rate model railroad power packs. I think it was because Lionel packs are AC and the volt-ampere is more often in AC terms, at least according to Wikopedia. It was explained to me that VA is volts times amps, which in most other electrical terms would be watts, but tradition is strong in model railroading, so we call them volt-amperes. If you have 8 volt-ampere power pack and divide by the max voltage of 10 you get .8 amps, which is power rating of a white Marklin pack.
Given .8 amps, the typical draw of a Z locomotive is something .2 amp, so the Marklin pack has plenty of juice for the job. I've run three MT F7's and GP's on one with no problems. I just hate that damned lever....
17 years 8 months ago #3100 by TerryH
Todd, thanks. I knew VA was a volt amp but I wasn't thinking along the line of watts. The only thing I was concerned with was the potential for a fire if a dead short occurred. I'm using a power bar with a circuit breaker for the three power packs as well as the ac/dc adapter for running up to 50 DC LEDs. The stranded 20 gauge wire along with 12 gauge solid core wire for bus lines (since I have tons of it) should be fine. I would appreciate it if anyone knows of a problem with this configuration to please let me know.
17 years 8 months ago #3106 by Havoc
While that is a good idea it won't help when shorting the output of your transformers. Check the fuse rating on the power bar and see what the maximum is the power packs can deliver. Now calculate how much power your bar can deliver before the fuse blows (voltage on the house in volts wiring multiplied by fuse rating in amps). probably it is only a tiny fraction.
You need to check each pack if it is protected on the output. Likely there are symbols on the back or bottom telling you it is fused (and what rating) or thermally protected.
17 years 8 months ago - 17 years 8 months ago #3111 by TerryH
Havoc, nothing is indicated on the transformers, so I check the Marklin FTP archives and determined each transformer is equipped with an internal thermal cutout switch which should reset itself in one minute after setting throttle to zero, So the transformers are covered, the power bar ensures me that all transformers are turned off, so as not to get any feed through by accident. The 12V DC Regulated Adapter is 1000mA and can power up to 50 LEDs. It is RoHS circuitry. I assume there is no thermal cutout in it. The power bar breaker is 15A and the main circuit breaker panel is 20A. The only real fire potential I can see is if the Regulated Adapter goes up in smoke. Not sure how to avoid this other then checking the load across it. Thank you very much for all your help.
17 years 8 months ago #3137 by Havoc
Good job you did.
Check if there isn't any marking on it like the symbol here commons.wikimedia.org/wiki/File:Fuse_symbol_Europe.svg indicating there is a fuse inside, or commons.wikimedia.org/wiki/File:Thermistor.svg to indicate a hermal safety. It doesn't tell you for that last if it resets itself but at least you kow something.
Something you could do to make sure is go to a car accesory or electronics shop and ask for an inline fuseholder. Something like this type is easiest: www.radioshack.com/product/index.jsp?productId=2102784 and buy 1A slow fuses to go with it. Then put it in one of the wires from your adaptor.
17 years 8 months ago - 17 years 8 months ago #3139 by TerryH
Havoc, only other symbol on it is the UL. Kick me in the head, I should of thought of an inline fuse. Thanks very much, I will do that.
Time to create page: 1.242 seconds
