New Rokuhan Products Now In Stock!
12 years 2 months ago #17523 by ztrack
New Rokuhan Products Now In Stock! was created by ztrack
ROKUHAN NEW RELEASES!
Ztrack Distribution is excited to announce we now have a number new and exciting Rokuhan products in stock!
Commuter train starter set:
Set includes powered railcar, controller and kidney shaped oval of track.
Deck girder bridges:
Available in green, dark red and dark grey
Commercial buildings:
Three different versions are in stock
Office buildings:
Corner office buildings:
Two different versions are in stock
Farm houses:
A number of new houses and farm-house are in stock, with either thatched roofs or metal roofs.
Super elevated track:
Now available in R245 – 30 degree sections and R270 – 30 degree section with either wood or concrete ties.
Track elevation risers:
Two different versions are in stock for either single track or double track. Used for a smooth transition with the Rokuhan viaducts.
LED lighting system:
New white and yellow LEDs with socket system.
Power cable extension:
This is used to split off power feeds from the controller.
New 20’ containers:
These include Evergreen, Hyundai, Hamburg and others
These items and many other Rokuhan products are available to order direct through our Track site or through any Ztrack Distribution authorized dealer.
www.zscaletrack.com
Rob Kluz
Ztrack Distribution
12 years 2 months ago #17526 by eit27
Replied by eit27 on topic New Rokuhan Products Now In Stock!
Rob,
Are the building kits or fully assembled?
12 years 2 months ago #17527 by ztrack
Replied by ztrack on topic New Rokuhan Products Now In Stock!
They are fully assembled. I think they could be Americanized fairly easily. There is some real potential with them.
12 years 2 months ago - 12 years 2 months ago #17528 by garthah
Replied by garthah on topic New Rokuhan Products Now In Stock!
drive.google.com/folderview?id=0BzByZrAx0gLHdG55Ml84RE5wNXc&usp=sharing
here are some pictures of Rokuhan buildings including several showing building taken apart an put back together again.
buildings some fully assembled, but can be pulled apart very easily, there are assembled without glue, the side panels fit into raised floor with tabs in slots, the roof is held in place by the slot at top of each wall piece and wall have pins and sockets, So to disassemble first pull building straight up off of it's base. Then you can pull one side of building out at a time and once you have two wall out the roof will come out. The tabs and lots are keyed so it only goes together in one way, however you can swap panels between different buildings of the same design. With the panels laying out flat it is easy to paint or add detail to floor as there are raised features on main floor so you could detail a hotel lobby or shop if desired and there is a hole for LED lighting in the main floor and a notch in the curb of the main building or wiring to go under floor and the Rokuhan lighting system is plug and play as LED are made to fit into opening in floor. There is a cable (A016) to connect 5 LEDs to the accessory socket on a Rokuhan controller plus it has a socket to add additional junction strips to expand lighting system. If you are doing your own thing remember LEDs work on DC only. (A017-1) is white LED for Fluorescent or Haloen type lighting and (A017-2) is white-orange for incandescent lighting effect.
Time to create page: 1.218 seconds
