- Thank you received: 86
Temporary Adhesive?
- Mr.JA
16 years 9 months ago #7835
by Mr.JA
Temporary Adhesive? was created by Mr.JA
Any recommendations (from experience) about a temporary adhesive for securing figures to locomotives or layouts? Some thing that will not leave a mark or damage painted surfaces and is easily removable.
I just received a diorama built by Jim O’Connell.
I plan to use it to photograph my growing collection of customized locomotives and rolling-stock. I plan to place people and/or vehicles on the diorama, but do not want to mount any thing permanently.
I believe this was discussed recently, but I cannot remember if it was here on ZCS or Trainboard or the yahoo group. I did not have any luck with my limited search abilities.
- Beverly56
16 years 9 months ago #7837
by Beverly56
Replied by Beverly56 on topic Re:Temporary Adhesive?
Alex,
I've used rubber cement on other projects for the purpose you need. The rubber cement rubs off easily when you're finished and shouldn't leave any marks. However, you should test it first just to be safe. Rubber cement is available at craft stores, and probably hardware and office supply stores, too. And it's pretty inexpensive. HTH
- Mr.JA
16 years 9 months ago #7838
by Mr.JA
Replied by Mr.JA on topic Re:Temporary Adhesive?
Beverly56 wrote:
Thank you, but I don't want to use anything that might pull up custom paint or scenery material.
I was thinking if glue stick might work. There is a type of glue stick that allows you to remove two pieces of paper stuck together with it.
- BillMock
- Thank you received: 1
16 years 9 months ago #7839
by BillMock
Replied by BillMock on topic Re:Temporary Adhesive?
Hi Alex,
I've used Woodland Scenics "Accent Glue".
"Instant placement...no holding required; Leaves no puddles; Allows repositioning of figures. Compatible with plastic, wood, or metal. Scuff glue points with sandpaper. Apply glue and wait until it is clear and tacky, then place figure or detail on layout."
It's just that easy Alex. And you can reposition with ease. I use it to secure my flatcar loads as well. After the glue has setup, I dab it with my finger to reduce some of the tackiness and then I can reposition large flatcar loads with ease.
Cheap. It's like $4.50 a bottle.
Good luck!
Bill Mock
Good luck!
Bill Mock
- Beverly56
16 years 9 months ago #7841
by Beverly56
Alex,
The "cement" part of rubber cement makes it sound like contact cement which is a very stong cement that I would not recommend. Rubber cement rubs off easily and should not damage anything. There is no preparation of surfaces necessary when using rubber cement. Elmer's is the brand I've used with great success for the purpose you need. Read this for a bit of information about Elmer's Rubber Cement .
- Mr.JA
16 years 9 months ago #7843
by Mr.JA
BillMock wrote:
I think I might already have some of it. Thank you, Bill!
Time to create page: 0.446 seconds
