Z scale pages back on line
12 years 8 months ago #17072 by garthah
Z scale pages back on line was created by garthah
MY web site with Z scale information, is back on line after a major attack and being unusable for many months I had two web sites originally Nn3.ca, where the Z scale information resided, and VE3HO.ca. Now the "Z" information has been moved from Nn3.ca and it has been closed. The "Z" scale stuff can be found under "Model Trains" in the menu on ve3ho.ca. There are 4 pages about Japanese Z and 4 about North American Z. In the Nn3 section there is a page on converting the Tomytec or Tomix TM series of power chassis to run on 6.5 mm track. they are many versions of these that are 2 and 4 axle powered and a variety of lengths with flywheel and easy to DCC units. They are available on Hobby Search in Japan and Plaza Japan, for those looking for a power unit for a Z scale project, this might provide some inspiration. I have actually made new chassis floor to mount the trucks on so you do not need to use the wide N scale originals. There is also a page on how to convert Micro trains non power routing turnouts to power routing, I figured this out so I could make a double main line with cross overs so I could run two separate trains from separate power packs, and did some directional lighting so you could see which direction the track power was set. Another thing I did but did not document was put red and green LED's in road bed edge to indicate turnout position.
12 years 8 months ago #17073 by Mr.JA
Time to create page: 0.198 seconds
