- Thank you received: 192
The 9 Volt Snail Speed Controllers are back!
- ztrack
16 years 10 months ago #7611
by ztrack
Ztrack Center is excited to announce that the Snail Speed 9volt battery controllers are back! These amazing little devises operate on a 9 volt battery (not included). They feature:
Low speed control
Smooth acceleration and braking
Overload protection
Pulse modulation
Larger control knob for ease of use
Ztrack Center has these in stock and ready to ship.
Ztrack Center also has received a new shipment of the Zthek Universal Snail Speed Controllers. The Universal allows your choice of 9volt battery operation or run from a wall outlet for extended life. The Universal controllers are available in both a domestic and international version.
To order, please visit:
www.ztrackcenter.com/electronics/index.html
The 9 Volt Snail Speed Controllers are back! was created by ztrack
Low speed control
Overload protection
Pulse modulation
- Mr.JA
- Thank you received: 86
16 years 10 months ago #7615
by Mr.JA
Replied by Mr.JA on topic Re:The 9 Volt Snail Speed Controllers are back!
Besides the larger knob, is there any other difference or improvements over previous versions of the 9 Volt Snail Speed Controllers?
Does the new shipment of Zthek Universal Snail Speed Controllers include the larger knob design or any other improvements?
- ztrack
16 years 10 months ago #7620
by ztrack
Replied by ztrack on topic Re:The 9 Volt Snail Speed Controllers are back!
Yes, the electronics are slightly improved over the previous releases.
- saundebn
16 years 10 months ago - 16 years 10 months ago #7627
by saundebn
Replied by saundebn on topic Re:The 9 Volt Snail Speed Controllers are back!
Follow-up questions ... as TechRep asked, do any of the new product designs apply to the Universal controller as well?
Also, is the 9V AC-adapter power to the Universal controller done via the single tethered cable or do you have to plug the adapter right into the controller itself? Certainly would seem inconvenient if two cables to the controller were needed.
Thanks, Brad
Thanks, Brad
- ztrack
16 years 10 months ago #7628
by ztrack
Brad,
The design changes and upgraded electronics only apply to the 9volt battery controller at this time. The Universal controllers have not been changed, but may once the current inventory is depleted.
The wall adapter does plug into the Universal Controller. This makes handling much easier, plus you can removed the wall adapter completely when running off of battery.
- ztrack
16 years 10 months ago - 16 years 10 months ago #7629
by ztrack
- saundebn
16 years 10 months ago #7630
by saundebn
OK, I suppose that one could take the power adapter cable and bind it up in some way with the other leads to imitate a single cable, assuming that the length of the two cables are reasonably close.
Based on your answer, it appears that the Universal controller isn't getting the design refresh just yet.
Time to create page: 0.235 seconds
