Got a problem with the forum
17 years 1 month ago #6368 by Catt
Got a problem with the forum was created by Catt
you see that grey bar up there? Do you see where it says My Z Central?Well that bar goes all the way across but if you go down below it,and to just this side of the a in Central the page just disappears.There is nothing there but a big ol white spot.This white area goes all the way to the bottom of the page.
I'd like to visit chat but other than the chat window itself there is nothing there.
In case you are wondering I am using IE 8.
I hope someone can come up with a solution for this little bit of aggravation.
17 years 1 month ago #6369 by Socalz44
Replied by Socalz44 on topic Re:Got a problem with the forum
Johnathon, I have tried every possible combination of moves that you discribe and cannot get your results. Perhaps the problem lies with you equipment. Someone else will chime in and then we can see what' up. As for Chat. True. Nothing appears below in. Simply click on Chat and the Chat page will open up for you. If not then again, the problem probably lies at you end. Cheers, Jim CCRR:huh:
17 years 1 month ago #6375 by David K. Smith
Replied by David K. Smith on topic Re:Got a problem with the forum
Did you try clicking the Compatibility button in IE? It's the button to the right of the address bar with a broken page icon.
17 years 1 month ago #6378 by Catt
Replied by Catt on topic Re:Got a problem with the forum
No I didn't David.What I did do was dump IE 8 which I was not happy with anyway.Now Z Central is back to Normal.:)
17 years 1 month ago #6393 by David K. Smith
Any chance of toning down the "You are using IE6! Bad, bad, bad user!" message? At work, I have no choice of which browser I can use, and the message that greets me every time I access Z Central is unnecessarily large and invasive. I realize it's a minor point, but it gets progressively more annoying every time I return to Z Central. (Perhaps, if not reduce/eliminate the message, maybe wire it up so it will only display once for any given visitor's IP address.)
17 years 1 month ago #6397 by GNFan
Replied by GNFan on topic Re:Got a problem with the forum
I second David's motion about the IE6 scolding message. We're stuck with IE6 at work (even as conflicts with websites and IE6 are piling up), too.
Mike
17 years 1 month ago #6399 by Socalz44
Guys, I think I am running into the same problems you are. I've erased the email to Brad including the possible IE6 notice so I can't reread it. While I'm not sure we are talking about the same thing, mine had to do with photo uploading, I did get the 'message'. While big and bold I didn't take it with any personal feelings. I'm not sure that IE would like their messages send any other way and ZCS certainly can't control IE's warning messages. What do you want, think, we can do for you? Cheers, Jim CCRR:unsure:
17 years 1 month ago #6400 by David K. Smith
Jim, the message is most definitely generated by Z Central, and it's not related to the image uploading process. It appears whenever the site is accessed by IE6, and advises us to upgrade to IE8 or some other "modern" browser, with this long-winded explanation why that consumes nearly half the screen. It looks like Brad might be working on it, because the message no longer appears, although the screen does go black, with a "Loading..." prompt in the center, for a couple of seconds when the site is accessed with IE6 now. So, thank you Brad, if you are indeed tinkering with the code.
17 years 1 month ago #6401 by Socalz44
Thanks David. I don't see the message anymore myself. I will direct him to this thread however. Cheers, Jim CCRR:)
17 years 1 month ago #6407 by bsteg
Replied by bsteg on topic Re:Got a problem with the forum
Message disabled. However, the site may not work so good for those browsing with 2001's IE6.
17 years 1 month ago #6414 by David K. Smith
Thanks for doing that! As it happens, it looks fine to me in IE6.
Time to create page: 0.224 seconds
