Märklin transformator
13 years 3 months ago #16075 by pm-ger
Märklin transformator was created by pm-ger
Hello Guy,
I'm planning to sell some of my Märklin collection, and also looking to sell them world wide.
The reason is that I plan to change the eldery locomotives uses 3 pol motors. So I looking forward to change to 5 pol, and change the track to Rokuhan.
The question I like to ask you, if the orginal Märklin transformators will work in the US.
I'm not sure if they will work, well becasue you use 110V AC. It's not clear because I saw on the
bottom of the trafo only that it is to 220V AC.
13 years 3 months ago #16078 by markm
Replied by markm on topic Re: Märklin transformator
Pete,
The 220V AC transformers are not much use in the U.S. Depending on the model of your locomotives, you might want to consider upgrading to the 5 pole motor rather than sell them. For some locomotives, there is not a 5 pole motor model to replace the 3 pole versions and for at least some of the locos, it's not hard to swap out the motor.
13 years 3 months ago #16079 by pm-ger
Replied by pm-ger on topic Re: Märklin transformator
Hi Mark,
thanks for you feedback.
As you mid know a new motor is quite expensive. So from my understanding is that that makes no sence, to change the motor. You right for the locos you like save for yourself.
Also I tried to change the motor for an old express electric loco BR 103 were the original motor was defect. So I have ordered an new 5 pole, but it doesn't fit the old base. I don't get it to work.
On the other hand the old 3 pole locos even runs well when you clean the power transmission.
Best regards
Pete
13 years 3 months ago #16080 by Minuteman
Replied by Minuteman on topic Re: Märklin transformator
Pete
I wouldn't recommend using the Marklin 220V controller in the US. In theory, you could use a step up converter to increase voltage from nominal residential 110V (actually 120V) to 220V, but the circuit breakers of the controller might trip way too late so any overload power surge could cause great harm. You'd need a fused step-up transformer, and this is where you'll find it just isn't economical to have that kind of setup.
Just my 10 cents ;)
Adrian
13 years 3 months ago #16081 by pm-ger
Hi Adrian,
thanks. I saw already that there mid be some problems.
Looking forward to get a suiatable converter.
I already have some contact. Looking forward to the results.
Best regrards
Pete
13 years 3 months ago #16082 by garthah
Replied by garthah on topic Re: Märklin transformator
220 vac tranformer is for use in Europe and many other countries, but not all. To use effectively here it needs a step up transformer that step 110vac up to 220vac. Even though we use 220vac for our clothes dryers and stoves and ovens, unless you know what you are doing, don't connect here as our plugs for 220vac are different
Time to create page: 1.448 seconds
