- Thank you received: 188
Rigging Crane
- southernnscale
13 years 6 months ago - 13 years 6 months ago #15631
by southernnscale
Rigging Crane was created by southernnscale
Today I was out shopping around and stopped in Michael Craft shop. I found this Transparent Polyester Tread 400 yds. 365m Art. S995-A2-Color 9950 It's black. it's very fine almost like hair! But it don't come apart like thread. and it goes thru the holes easier! It's $2.49 a spool. I attached a Picture so you can see the different size between the two.
The thread has fibers which makes it hard to put thru the small holes. The poly line is a singe piece with no fibers.
The following user(s) said Thank You: zscaler66
- Heavy-Equipment-Designer
- Thank you received: 67
13 years 6 months ago #15634
by Heavy-Equipment-Designer
Replied by Heavy-Equipment-Designer on topic Re: Rigging Crane
Walt, I highly suggest you also look at Kimono Silk Thread #100. Its .16 mm DIA 3 strand silk. Even though its made of the strands, there are no fuzzes. You might find the poly mono strand does not like to bend around the pulleys to well and almost impossible to keep the lines taught. The Kimono Silk is very soft and very playable. So bends really well around the pulleys and stays taught. And since its so soft, its easy to rig up your boom. But if it still gives you a hassle, an old model ship rigging trick is to run the end of the thread through some crazy glue and cut the end off at an angle. You now have a built in needle... It comes in 80 different colors. But the only color I've ever seen wire cables come in are silver metal covered in grease or rust covered in grease... But you can get black... Its a little more expensive (about $6 for 220 yards) but its worth every penny. I posted some images of a rigged up boom on the Industrial Brownhoist Topic. I do have some lead BB in the inside of the boom but its really not needed to keep the lines taught. If you want to check the thread out, go here www.superiorthreads.com/shop/category/thread/?Brand=Kimono+Silk&page=5
The following user(s) said Thank You: Fred, southernnscale, Bill_O
- southernnscale
13 years 6 months ago #15635
by southernnscale
Replied by southernnscale on topic Re: Rigging Crane
Thanks for the information sounds like I might try some out to see how it works.
Thank,
Walt
Thank,
Walt
Time to create page: 0.186 seconds
