- Thank you received: 188
Z scale track
- southernnscale
14 years 1 month ago #14373
by southernnscale
Z scale track was created by southernnscale
Does any one know if the Rokuhan Z scale track work with the Micro trains Z scale track?
- ztrack
- Thank you received: 192
14 years 1 month ago #14375
by ztrack
Replied by ztrack on topic Re: Z scale track
Yes, you can use the Rokuhan and MTL ballasted track together. There is an ever so slight hight difference, but it is minimal. A swipe of a file will match up the rail heads. In my opinion, the only distraction is the tie spacing when you use the two systems together. The MTL track spacing is nice and tight and matches North American rail. The Rokuhan tie spacing is much farther apart with wider ties.
- markm
- Thank you received: 69
14 years 1 month ago #14379
by markm
Replied by markm on topic Re: Z scale track
The roadbed joiners are not compatible and need to be removed. If you're refering to the MTL flex track, there is a connection adapter: A014.
14 years 1 month ago #14381
Replied by garthah on topic Re: Z scale track
If you pull the roadbed joiner from the MTL roadbed track and replace it with one from Rokuhan track that works, but the MTL one is a bit wider than rokuhan so it won't fit into the slot on Rokuhan track without causing damage and jamming in the slot, however the rokuhan one works fine in the MTL track. I find that if you remove the rail joiner and the road bed joiner and replace with ones from Rokuhan it is very easy to connect the two together and then a bit of dressing with a file at the rail joint eliminates any bumps due to slight difference in height of each manufacturers rail.
beste regards Garth
beste regards Garth
Time to create page: 0.333 seconds
