MU Speeds
16 years 8 months ago #8445 by Socalz44
MU Speeds was created by Socalz44
I have two GP9's. One is just a little bit slower than the other. If I MU them which engine do I want in the lead? Cheers, Jim CCRR:unsure:
16 years 8 months ago #8449 by andyjbj
Replied by andyjbj on topic Re:MU Speeds
great question, same problem with some Marklins.
16 years 8 months ago #8450 by shamoo737
Replied by shamoo737 on topic Re:MU Speeds
Jim, dcc them and adust their speed . Ok, this is my real answer. Run the faster engine in the lead. That is because the faster engine will pull the slower engine. If you run the slower engine first, the faster engine will catch up to the slower engine causing a slack in the coupler, and it will cause uncoupling, specially on a curve.
16 years 8 months ago - 16 years 8 months ago #8461 by Gerd
Replied by Gerd on topic Re:MU Speeds
just pull the shells off the locos and re-adjust the screws keeping the chassis together. It's no joke, MTL seems to have some variation in the assemnbly process and by adjusting the tightening you can achieve the same speed....I do it this way
16 years 8 months ago #8464 by Socalz44
Replied by Socalz44 on topic Re:MU Speeds
Gerd, Great tip. Do you trust me to try this? Or should I get my friend Don Fedjur from the ZoCal group to do it? Cheers, Jim CCRR:unsure:
16 years 8 months ago #8473 by Gerd
easy, just lift up the shell as in the MTL instruction, can't do it wrong...or?
Time to create page: 0.793 seconds
