- Thank you received: 7
Experience with Rokuhan superelevated curves ?
- Minuteman
12 years 5 months ago #17302
by Minuteman
Experience with Rokuhan superelevated curves ? was created by Minuteman
As the Rokuhan superelevated curves have been around for a moment now, I was wondering if anybody has some hands on experience actually running trains through them? According to the Rokuhan youtube video the cant is 5,5 degrees, which at least on paper seems a bit much for a secondary freight line (I know by coincidence that the maximum cant in the UK is 6 degrees).
I have always put my curves down with a slight cant, if only for visual reasons, so I'm basically wondering what the practical experiences with Rokuhan's superelevated curves are.
Thanks for sharing
Thanks for sharing
12 years 5 months ago - 12 years 5 months ago #17306
Replied by garthah on topic Re: Experience with Rokuhan superelevated curves ?
I have had no trouble with them on my demo layout that I take to shows, People sure notice it when an engine leans into the curve, they seem to hold their breath wondering if it is going to topple or not.
The following user(s) said Thank You: Mr.JA, Minuteman
- ModelWarships
- Thank you received: 12
12 years 5 months ago #17307
by ModelWarships
Timothy Dike
Replied by ModelWarships on topic Re: Experience with Rokuhan superelevated curves ?
I installed a few of them on my layout. They are fine except for the abrupt transition from level to elevated. I am going to try sanding the first curve outside edge to gradually go from flat to curved and see how that goes.
Timothy Dike
The following user(s) said Thank You: Minuteman
- markm
- Thank you received: 69
12 years 5 months ago #17317
by markm
Replied by markm on topic Re: Experience with Rokuhan superelevated curves ?
I've been using the 220mm superelevated curves with a 245mm curve as lead in. I glue down the end of the 245mm that's opposite the superelevated end and the inside edge of the curve. I let the outside edge float. It seems to work well for the transition. I plan to add ballast along the outside edge to hide the gap between the roadbed and bench work.
Time to create page: 0.642 seconds
