Z Bend Track Modules Legs
14 years 1 month ago #14429 by TheWag
Z Bend Track Modules Legs was created by TheWag
How do you do yours? I have a couple ideas, but would like to know what other people are using and works.
14 years 1 month ago #14430 by rvn2001
Replied by rvn2001 on topic Re: Z Bend Track Modules Legs
This is how I make mine. They are adjustable from banquet table height to the 50" ZBT standard height.
14 years 1 month ago #14431 by TheWag
Replied by TheWag on topic Re: Z Bend Track Modules Legs
Hmm, 2 pieces of PVC. Some bolts, wingnuts, leveler, caps, and I guess it just screws in to the module? About what width did you use?
I'm guessing the most difficult part was drilling all the holes!!
Ben
14 years 1 month ago #14433 by rvn2001
Ben,
The outside tube is 1+1/4 inch schedule 40 pvc tubing. This is thick walled tubing. The inside tube isn't marked but fits just inside the outside tube. This is also thick walled tubing. I made a jig to get all the holes to line up all the time. There is a 2" x 2" block of wood with a "T" nut installed in each corner of the module to receive the screw in the top of the leg which is a 1/4-20 carriage bolt.
The legs would be more stable with a cross brace made out of 2 pieces of pvc "T" connector large enough to go over the leg with a piece of pvc between them and holes drilled through the connectors to install a bolt through the connectors and legs.
Time to create page: 0.333 seconds
