Bolster pin removal and installation tool(s)?
17 years 1 month ago - 17 years 1 month ago #6326 by Mr.JA
Forgive me for what may be a stupid, simple question. :blush:
I'm in the process of replacing a good quantity of MTL trucks with Bowser Bucklers.
I can do it, but I'd like to not mark up the bolster pins during removal... if possible.
I'd like to hear what folks are using to remove their bolster pins.
Any preferred tools?
Any special tools?
17 years 1 month ago #6327 by rvn2001
Hi Alex,
I use a small flat-blade screwdriver and pry between the truck frame and bolster to lift out the truck and bolster pin at the same time.
This should make your job a little easier,
Thom
17 years 1 month ago #6329 by garthah
I also use a small flat blade screw driver with fine chisel point to pry between truck and car bolster to remove truck and pin. Once inserted just a gentle twist will do the job normally.
17 years 1 month ago #6330 by Socalz44
I concur. That is how I've always done it. I tried needle nose pliers once with mixed results. Smallest flathead works well. Cheers, Jim CCRR:)
17 years 1 month ago #6331 by shamoo737
Replied by shamoo737 on topic Re:Bolster pin removal and installation tool(s)?
I use a rail cutter and wedge it into the pin, and lift up the bolster pin. I think its easier.
17 years 1 month ago - 17 years 1 month ago #6336 by David K. Smith
Replied by David K. Smith on topic Re:Bolster pin removal and installation tool(s)?
I insert the tips of a pair of tweezers between the truck bolster and the car frame, one tip on either side of the pin, then lift the handle of the tweezers to gently pry the truck up. This equalizes the stress on the pin; sometimes, particularly stubborn pins will bend and distort when the truck is being pried from one side using a screwdriver.
17 years 1 month ago #6342 by SJ-BAZ-man
Replied by SJ-BAZ-man on topic Re:Bolster pin removal and installation tool(s)?
I have an End Cut style. 90 degrees. Point it straight at the boldter pin head and it slips under it, like a wedge. I ground the middle of each cutter round so that it creates a hole, no way to cut the pin off.
Sadly, they are no longer made (and I continue to periodically search for a replacement).
17 years 1 month ago #6343 by David K. Smith
Is there a specific one you're looking for? Here's a few I found:
cgi.ebay.com/Xuron-Double-Flush-Cut-Shears-Strong-Easy-Pliers-New_W0QQitemZ360194365644QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item53dd41d8cc#ht_1464wt_1165
www.timemotion.com/Products/Cutter--530E-US-Anti-Shock-Shear-Cutter--Excelta__WAS-03-34530.aspx
cgi.ebay.com/4-INCH-JEWELRY-WIRE-CUTTING-END-CUTTER-PLIERS_W0QQitemZ290360339211QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item439ad32b0b#ht_3384wt_1165
cgi.ebay.com/Wire-cutter-set-Side-and-end-cutting-set-cushion-grip_W0QQitemZ140352802792QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item20adadcfe8#ht_500wt_1182
cgi.ebay.com/6-PC-PRECISION-JEWELRY-MINI-PLIER-TOOL-SET-pmp-6_W0QQitemZ250515485371QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3a53e2f2bb#ht_3627wt_924
www.amazon.com/dp/B0012O96BM/ref=asc_df_B0012O96BM941836?smid=AG275D7O3JJ72&tag=dealtmp15458-20&linkCode=asn&creative=380341&creativeASIN=B0012O96BM
www.amazon.com/dp/B000SKVER0/ref=asc_df_B000SKVER0940260?smid=A10GXORWB75SLM&tag=shopzilla_rev_273-20&linkCode=asn&creative=380341&creativeASIN=B000SKVER0
www.amazon.com/dp/B0000BYBCO/ref=asc_df_B0000BYBCO940226?smid=ADFRQ5K4I2LNR&tag=shopzilla_mp_1198-20&linkCode=asn&creative=380341&creativeASIN=B0000BYBCO
www.sears.com/shc/s/p_10153_12605_00993033000P
Time to create page: 0.388 seconds
