MTL F-7 question
13 years 5 months ago #15808 by Mr.JA
MTL F-7 question was created by Mr.JA
I thought this was discussed before, but I'm not finding the thread. Then, again... it could be posted on one of those other forums.
I have a new MTL F-7 A-unit. It runs fine in reverse. The usual coffee grinder. Switch to forward... it runs... it starts to slow down... it sputters... it stops. Put it in reverse... no troubles.
Anyone have any ideas or tips?
ThankZ!
13 years 5 months ago - 13 years 5 months ago #15809 by rvn2001
Replied by rvn2001 on topic Re: MTL F-7 question
run it backwards as a cab-backward?? ;-) :0)
13 years 5 months ago #15810 by markm
Replied by markm on topic Re: MTL F-7 question
Don't know if this is the "right" answer or what you'd want to read, but when I've changed the brushes on the motor I've experienced similiar one way issues when I didn't get them in right.
13 years 5 months ago #15811 by Mr.JA
Replied by Mr.JA on topic Re: MTL F-7 question
I don't know, Mark. I wasn't aware that the MTL F-7's had brushes. I've never seen a F-7 run like this.
Before I open it up... Is there anything I need to be aware of? Just loosen the four screws and ?
13 years 5 months ago #15812 by markm
Yeah they have brushes. Check out the instruction sheet in the bottom of the jewel box. Spread the shell with a toothpick in the center at the chasis to get it off. Fig 1 in the instructions shows the rest. Of course if its new, I'd consider it a factory issue. If they installed the brushes wrong, what other issues might you find?
13 years 5 months ago - 13 years 5 months ago #15813 by southernnscale
Replied by southernnscale on topic Re: MTL F-7 question
Mr. JA, Do you think it might be your controller. since forward is used more then reverse maybe the controller may be worn down bad try a different controller. Just a thought! :unsure:
13 years 5 months ago #15815 by shamoo737
Replied by shamoo737 on topic Re: MTL F-7 question
Walt, I blame it on the controller of the controls.
13 years 5 months ago - 13 years 5 months ago #15816 by southernnscale
So! What was the problem? :( It couldn't have been the controller of the control, you were in control! Right? :whistle: meaning the hand held controller or transformer forward of reverse.
13 years 5 months ago - 13 years 5 months ago #15817 by stonysmith
Replied by stonysmith on topic Re: MTL F-7 question
Unless I'm totally off my rocker, there are also a set of (brushes) also known as wheelwipers that pickup power off of the wheels. They are in the shape of an upside-down V. If one of those surfaces on the wiper is dirty, it's entirely possible that it will make good connection in one direction and poor connection going the other direction.
Plus, it could be actual 'dirt' or it could be simple oxidation. Might have to clean the wipers, or possibly even clean the wheels.
13 years 5 months ago #15819 by markm
There are always a lot of possibilities and the twisted motor brushes is the only one that meets the description that I've seen. The missing piece of info is whether the headlight stays on when the loco grinds to a halt. If so that pretty much eliminates the electrical issues (including operator error). ;-)
13 years 5 months ago #15821 by Mr.JA
southernnscale wrote: Mr. JA, Do you think it might be your controller. since forward is used more then reverse maybe the controller may be worn down bad try a different controller. Just a thought! :unsure:
It's not a controller issue. Other locos run fine... including other MTL F-7 units. :dry:
13 years 5 months ago #15822 by Mr.JA
markm wrote: The missing piece of info is whether the headlight stays on when the loco grinds to a halt. If so that pretty much eliminates the electrical issues (including operator error). ;-)
As the loco runs from normal to sputtering to dead stop... the headlight goes from steady to flickering to dead.
The track is clean... the controller is fine. Other locos of all types are running fine and normally on the same loop of track with the same controller. As I wrote in my original post... this is a NEW MTL F-7 A-unit.
13 years 5 months ago #15823 by Mr.JA
stonysmith wrote: Unless I'm totally off my rocker, there are also a set of (brushes) also known as wheelwipers that pickup power off of the wheels. They are in the shape of an upside-down V. Plus, it could be actual 'dirt' or it could be simple oxidation. Might have to clean the wipers, or possibly even clean the wheels.
Unless I'm off my rocker... wheelwipers on the MTL F-7's are an after-market add-on. Everything is clean... track and wheels.
13 years 5 months ago - 13 years 5 months ago #15826 by garthah
Replied by garthah on topic Re: MTL F-7 question
With everything else checked there is only one tiem left that I can see. The trucks on the F7 have some play front to back due to teeth and worm clearances at top of truck.If you try starting the F7 slowly, you can see the body move before the engine moves, when going forward the body moves forward a bit on the trucks as slack in worm drive is taken up and when going in reverse the same thing happens only body starts to move in reverse before the trucks do. so if one of the cats whisker bronze strips is out of tension,or position then in one direction you could have an open connection and the engine would run in one direction and not in the other. Usually if these strips are damaged the engine flops over on one side. These cats whiskers are phosphor bronze are easily damaged if the engine has been taken apart and on reassembly they were not in proper alignment when the second half of the body was put back on.The tip of the whisker contacts a very small area at the top of the truck, above the gimble so minor misalignment can lead to loss of contact. unfortunately the Glenn Chenier wipers do not solve this problem but they do improve overall operation when they are used, but the cats whisker sticks out from holes in body casting and have to positioned correctly and tensioned correctly to make contact and keep engine upright on its trucks.The trick to installing the Glenn Chenier contact strips is to do it by removing the truck side frames only and not opening the engine up. When you take the shell off make sure the end of the bronze strip is at least flush with side of body metal casting. they are just a friction fit in the holes. if they protrude from the outside of the body casting they are too short to make contact reliably. over 70% of the time whenI am repairing an F7 the i find the cats whisker is not correctly positioned or tensioned and is usually the first thing I have to fix to get it running again.
The following user(s) said Thank You: Mr.JA, markm
13 years 5 months ago #15827 by Mr.JA
ThankZ, Garth, for the details. I took off the shell, but did not open the chassis. My solution, since this is a new locomotive is to return it to MTL.
13 years 5 months ago #15828 by southernnscale
I'm sorry you have to retire your F-7 Engine to the bone yard! I've never had that problem with any of my Engines except for dirty track or a truck not setting right. One time I had two Engines on the same track and would run and the other not, I took one off and the other would run fine. So it stays a Mystery :huh: !!!!!!
Time to create page: 1.529 seconds
