- Thank you received: 1
AZL GP7 Wobble
- xj700
15 years 6 months ago #10833
by xj700
AZL GP7 Wobble was created by xj700
My AZL GP7 "wobbles" on the front trucks. Do any of your AZL's do that?
Better still, how do I get rid of this said "wobble".
Also, one other thing, with the Micro Train cars, how do I eradicate the "slinky" effect? Do I have to replace the trucks?
Thanks in advance.
Thanks in advance.
- shamoo737
- Thank you received: 30
15 years 6 months ago #10837
by shamoo737
Replied by shamoo737 on topic Re: AZL GP7 Wobble
The Wobble is not normal, I suggest that you contact Rob Kluz of Ztrak, he is the distributor of AZL. ON the slinky effect, MTL makes a truck retaining springs. That will help to reduce the slinky effect. Another trick you can use is couple it to a AZL coupler, or use metal wheels.
- ztrack
- Thank you received: 192
15 years 6 months ago #10840
by ztrack
Replied by ztrack on topic Re: AZL GP7 Wobble
Try this. I have found that a wobble can occur if the truck is not seated properly. Take the shell off, and unclip the chassis to remove the truck in question. Give it a good inspection and make sure it is rolling freely. Try reseating it. If the wobble does not go away, drop me an email and we can work out a resolution. My email is:
- xj700
15 years 6 months ago #10843
by xj700
Replied by xj700 on topic Re: AZL GP7 Wobble
Ok. I'll try working on it today after my job interview. Thanks both of you for the info!
Time to create page: 1.050 seconds
